How to seal with DeLonghi ESAM xxxx - the brewing group
  1. How to seal with DeLonghi ESAM xxxx - the brewing group, How to seal with DeLonghi ESAM xxxx - the brewing group: step 1, image 1 of 1
    • Press the two red buttons of the brew group together and remove the brew group.
  2. How to seal with DeLonghi ESAM xxxx - the brewing group: step 2, image 1 of 2 How to seal with DeLonghi ESAM xxxx - the brewing group: step 2, image 2 of 2
    • Lay the machine on its rearside, with the open frontside looking upwards.
    • The brewing strainer of the upper piston is fixed with two phillips screws PH2.Turn it out.
    • With some force, remove the brewing strainer and remove the old sealing ring.
    • Clean the brewing strainer and what is underneath is fine.
    • Grease the new sealing ring with food grade silicone grease. Put it on the piston and tighten the brewing sieve again.
  3. How to seal with DeLonghi ESAM xxxx - the brewing group: step 3, image 1 of 2 How to seal with DeLonghi ESAM xxxx - the brewing group: step 3, image 2 of 2
    • Pull the plastic retaining clip off the moving base of the brew group. It is just plugged.
    • Pull the bottom out of the black plastic piece.
  4. How to seal with DeLonghi ESAM xxxx - the brewing group: step 4, image 1 of 1
    • Press out the piston on the opposite side.
    • Remove the two sealing rings.
  5. How to seal with DeLonghi ESAM xxxx - the brewing group: step 5, image 1 of 1
    • The filter screen is attached with a phillips screw PH2. Turn it out. Take off the brewing sieve.
    • Clean brewing strainer and what is behind it is good.
  6. How to seal with DeLonghi ESAM xxxx - the brewing group: step 6, image 1 of 2 How to seal with DeLonghi ESAM xxxx - the brewing group: step 6, image 2 of 2
    • The crema valve is hard to recognize. It is covered with a plastic stopper. You can gently remove it with the sharp tip of a cutter.
    • He is very tight. Hoist piece by piece high with the cutter tip.
    • Underneath is the valve. It consists of a spring and a small piston. Clean everything very well, also the channels. Be very careful.
    • Plug in the valve again. Screw the brewing strainer tight and attach the two new sealing rings. Grease the sealing rings and the piston barrel thinly with food-grade silicone grease.
Repeat the steps in order to reassemble your device.
4 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
204,177 Reputation
246 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,132 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 49
All Time: 2,765
