Introduction
This guide will instruct you, step by step, in how to remove and replace the disk drive in your Vaio VGRFS640.
Remove the highlighted screws from the panels in the bottom right-hand corner of the laptop using the Phillips #0 Screwdriver.
Remove the two panels in the bottom right-hand corner by sliding in the direction of the arrows imprinted on the panels.
Remove the highlighted screws underneath the removed panels using the Phillips #0 Screwdriver.
Carefully remove the hard drive from the panel in the bottom right-hand corner of the laptop.
Locate the battery, located on the top side of the laptop to the right of the Service Tag .
Remove the battery by pressing inwards on the tabs on either side of the battery.
