Vaio FS series VGRFS640 CD DVD drive Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Vaio FS series VGRFS640 CD DVD drive Replacement, Backplate: step 1, image 1 of 1
    • Turn off the laptop and disconnect any charging cables.
    • Flip the laptop over so that the Service Tag is shown at the top left corner.
  2. Vaio FS series VGRFS640 CD DVD drive Replacement: step 2, image 1 of 1
    • Remove the highlighted screws from the back of the laptop with a Phillips #0 Screwdriver.
  3. Vaio FS series VGRFS640 CD DVD drive Replacement: step 3, image 1 of 1
    • Remove the highlighted screws from the panels in the bottom right-hand corner of the laptop using the Phillips #0 Screwdriver.
  4. Vaio FS series VGRFS640 CD DVD drive Replacement: step 4, image 1 of 1
    • Remove the two panels in the bottom right-hand corner by sliding in the direction of the arrows imprinted on the panels.
  5. Vaio FS series VGRFS640 CD DVD drive Replacement: step 5, image 1 of 1
    • Remove the highlighted screws underneath the removed panels using the Phillips #0 Screwdriver.
  6. Vaio FS series VGRFS640 CD DVD drive Replacement: step 6, image 1 of 1
    • Carefully remove the hard drive from the panel in the bottom right-hand corner of the laptop.
  7. Vaio FS series VGRFS640 CD DVD drive Replacement: step 7, image 1 of 1
    • Locate the battery, located on the top side of the laptop to the right of the Service Tag .
    • Remove the battery by pressing inwards on the tabs on either side of the battery.
  8. Vaio FS series VGRFS640 CD DVD drive Replacement: step 8, image 1 of 1
    • Remove cover in the top left side of the laptop next to the battery by pulling it outwards.
  9. Vaio FS series VGRFS640 CD DVD drive Replacement: step 9, image 1 of 1
    • Remove the backplate of the laptop by pulling it away from the laptop.
  10. Vaio FS series VGRFS640 CD DVD drive Replacement, CD DVD drive: step 10, image 1 of 2 Vaio FS series VGRFS640 CD DVD drive Replacement, CD DVD drive: step 10, image 2 of 2
    • Unscrew the screws holding in the CD/ DVD drive.
  11. Vaio FS series VGRFS640 CD DVD drive Replacement: step 11, image 1 of 2 Vaio FS series VGRFS640 CD DVD drive Replacement: step 11, image 2 of 2
    • Remove the CD/ DVD drive by gently lifting it up and out of the laptop.
  12. Vaio FS series VGRFS640 CD DVD drive Replacement: step 12, image 1 of 2 Vaio FS series VGRFS640 CD DVD drive Replacement: step 12, image 2 of 2
    • Get the new CD/ DVD drive.
    • Make sure that the new CD/ DVD drive is compatable with the Vaio VGRFS640
    • Sony no-longer has a list of compatable drivers, however the original driver can be found here under optical drive.
Geoffrey
252 Reputation
2 Guides authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 10
All Time: 183
