VTech MobiGo Touch Learning System Screen Replacement
  1. VTech MobiGo Touch Learning System Screen Replacement, Case: step 1, image 1 of 1
    • Remove the battery covers and the four batteries.
  2. VTech MobiGo Touch Learning System Screen Replacement: step 2, image 1 of 2 VTech MobiGo Touch Learning System Screen Replacement: step 2, image 2 of 2
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
  3. VTech MobiGo Touch Learning System Screen Replacement: step 3, image 1 of 2 VTech MobiGo Touch Learning System Screen Replacement: step 3, image 2 of 2
    • Using a plastic opening tool, separate the two pieces of the case carefully.
  4. VTech MobiGo Touch Learning System Screen Replacement, Disassembling VTech MobiGo Touch Learning System Screen Enclosure: step 4, image 1 of 1
    • Remove the three 4.0 mm Philips J0 screws holding the "L" shaped brackets in place.
  5. VTech MobiGo Touch Learning System Screen Replacement: step 5, image 1 of 1
    • Remove the three "L" shaped brackets and the spring.
  6. VTech MobiGo Touch Learning System Screen Replacement: step 6, image 1 of 1
    • Flip the device over and remove the three 4.0 mm Philips J0 case screws.
  7. VTech MobiGo Touch Learning System Screen Replacement: step 7, image 1 of 1
    • Separate the front and back of the case.
    • Use a plastic opening tool if necessary.
  8. VTech MobiGo Touch Learning System Screen Replacement, Screen: step 8, image 1 of 1
    • Remove the 4 (3.4 mm Philips J0) screws holding the screen in
  9. VTech MobiGo Touch Learning System Screen Replacement: step 9, image 1 of 1
    • Remove the black tape
  10. VTech MobiGo Touch Learning System Screen Replacement: step 10, image 1 of 1
    • Remove the circuit board from the back of the screen.
    • The circuit board has double sided tape on the back side holding it to the screen.
  11. VTech MobiGo Touch Learning System Screen Replacement: step 11, image 1 of 1
    • Peel the ribbon wire off of the circuit board. Now the screen should be free to remove.
  12. VTech MobiGo Touch Learning System Screen Replacement: step 12, image 1 of 1
    • Resolder the new screens ribbon cable on the the circuit board.
    • Always be careful when soldering.
Daniel Kresge
385 Reputation
4 Guides authored
USF Tampa, Team 8-3, Eyestone Fall 2015 Member of USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Members
17 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 10
All Time: 675
