Introduction
You no longer get sound from the speakers on your tablet. This guide will help you gain access to the speaker on your tablet for removal or replacement.
Lift the Leg all the way up and twist the bottom to remove.
Once the bottom part pops out the whole leg should just come off.
Remove any game cartridge from the device.
Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
Using a plastic opening tool, detach the backplate from the front piece.
Once the backplate has been removed, you will have access to the circuit board.
First remove the ribbon cables. There are two highlighted by the red squares
Do not apply too much pressure and make sure that the black plastic tabs are fully open before you pull the cable out.
Remove the board from the main assembly.
Be careful not to pull too hard so that the cables aren't broken.
