VTech InnoTab 2s Speaker Replacement
  1. VTech InnoTab 2s Speaker Replacement, Back Panel: step 1, image 1 of 1
    • Turn your device to where the back panel is facing you.
  2. VTech InnoTab 2s Speaker Replacement: step 2, image 1 of 2 VTech InnoTab 2s Speaker Replacement: step 2, image 2 of 2
    • Lift the Leg all the way up and twist the bottom to remove.
    • Once the bottom part pops out the whole leg should just come off.
    • Remove any game cartridge from the device.
  3. VTech InnoTab 2s Speaker Replacement: step 3, image 1 of 3 VTech InnoTab 2s Speaker Replacement: step 3, image 2 of 3 VTech InnoTab 2s Speaker Replacement: step 3, image 3 of 3
    • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
    • These covers are made of hard plastic so they may be difficult to remove.
    • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
  4. VTech InnoTab 2s Speaker Replacement: step 4, image 1 of 2 VTech InnoTab 2s Speaker Replacement: step 4, image 2 of 2
    • Remove all nine screws from the back of the device using a J0 bit.
    • Remove the small battery.
  5. VTech InnoTab 2s Speaker Replacement: step 5, image 1 of 2 VTech InnoTab 2s Speaker Replacement: step 5, image 2 of 2
    • Using a plastic opening tool, detach the backplate from the front piece.
    • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
    • Once the backplate has been removed, you will have access to the circuit board.
  6. VTech InnoTab 2s Speaker Replacement, Motherboard: step 6, image 1 of 1
    • First begin by removing the three cross-head screws using a J0 bit.
  7. VTech InnoTab 2s Speaker Replacement: step 7, image 1 of 1
    • First remove the ribbon cables. There are two highlighted by the red squares
    • Do not apply too much pressure and make sure that the black plastic tabs are fully open before you pull the cable out.
  8. VTech InnoTab 2s Speaker Replacement: step 8, image 1 of 1
    • Remove the camera from the assembly and put is a safe place so that it will not get damaged.
  9. VTech InnoTab 2s Speaker Replacement: step 9, image 1 of 1
    • Remove the board from the main assembly.
    • Be careful not to pull too hard so that the cables aren't broken.
  10. VTech InnoTab 2s Speaker Replacement: step 10, image 1 of 1
    • De-solder the points shown to fully remove the cables and free the board.
    • A soldering guide offered by IFIXIT can be found here Soldering Skills.
  11. VTech InnoTab 2s Speaker Replacement, Speaker: step 11, image 1 of 1
    • Desolder these two points from the circuit board.
    • A soldering guide provided by iFixit can be found here: Soldering Skills.
  12. VTech InnoTab 2s Speaker Replacement: step 12, image 1 of 1
    • Remove the two screws that are holding down the speaker.
  13. VTech InnoTab 2s Speaker Replacement: step 13, image 1 of 1
    • Desolder the two wires that are connected to the speaker.
    • A soldering guide offered by IFIXIT can be found here: Soldering Skills.
Esthevan Romeiro
261 Reputation
4 Guides authored
USF Tampa, Team 5-1, Lacy Fall 2016 Member of USF Tampa, Team 5-1, Lacy Fall 2016
USFT-LACY-F16S5G1
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 17
All Time: 260
