Lift the Leg all the way up and twist the bottom to remove.
Once the bottom part pops out the whole leg should just come off.
Remove any game cartridge from the device.
Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
Using a plastic opening tool, detach the backplate from the front piece.
Once the backplate has been removed, you will have access to the circuit board.
