VTech InnoTab 2s Back Panel Replacement
  1. VTech InnoTab 2s Back Panel Replacement, Back Panel: step 1, image 1 of 1
    • Turn your device to where the back panel is facing you.
  2. VTech InnoTab 2s Back Panel Replacement: step 2, image 1 of 2 VTech InnoTab 2s Back Panel Replacement: step 2, image 2 of 2
    • Lift the Leg all the way up and twist the bottom to remove.
    • Once the bottom part pops out the whole leg should just come off.
    • Remove any game cartridge from the device.
  3. VTech InnoTab 2s Back Panel Replacement: step 3, image 1 of 3 VTech InnoTab 2s Back Panel Replacement: step 3, image 2 of 3 VTech InnoTab 2s Back Panel Replacement: step 3, image 3 of 3
    • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
    • These covers are made of hard plastic so they may be difficult to remove.
    • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
  4. VTech InnoTab 2s Back Panel Replacement: step 4, image 1 of 2 VTech InnoTab 2s Back Panel Replacement: step 4, image 2 of 2
    • Remove all nine screws from the back of the device using a J0 bit.
    • Remove the small battery.
  5. VTech InnoTab 2s Back Panel Replacement: step 5, image 1 of 2 VTech InnoTab 2s Back Panel Replacement: step 5, image 2 of 2
    • Using a plastic opening tool, detach the backplate from the front piece.
    • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
    • Once the backplate has been removed, you will have access to the circuit board.
Ricardo Espinosa
221 Reputation
2 Guides authored
USF Tampa, Team 5-1, Lacy Fall 2016 Member of USF Tampa, Team 5-1, Lacy Fall 2016
USFT-LACY-F16S5G1
4 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 252
