Upper Main Flex Connector Disconnect Procedure
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Upper Main Flex Connector Disconnect Procedure, Back Cover: step 1, image 1 of 2 Upper Main Flex Connector Disconnect Procedure, Back Cover: step 1, image 2 of 2
      • Before you begin, switch off your phone.
      • Remove the SIM card tray.
      Ask FixBot
    2. Upper Main Flex Connector Disconnect Procedure: step 2, image 1 of 1
      • Remove the two Torx T2 screws (2.5 mm length).
      • The OnePlus 5T doesn't use a lot of adhesive to secure the backcover, however the clamps are very strong and require some force during the opening procedure.
      Ask FixBot
    3. Upper Main Flex Connector Disconnect Procedure: step 3, image 1 of 3 Upper Main Flex Connector Disconnect Procedure: step 3, image 2 of 3 Upper Main Flex Connector Disconnect Procedure: step 3, image 3 of 3
      • Insert an opening tool between the display and the backcover at the bottom end of the phone.
      • Use the opening tool to create a gap between back cover and display.
      • Insert an opening pick in the gap you created with the opening tool.
      Ask FixBot
    4. Upper Main Flex Connector Disconnect Procedure: step 4, image 1 of 3 Upper Main Flex Connector Disconnect Procedure: step 4, image 2 of 3 Upper Main Flex Connector Disconnect Procedure: step 4, image 3 of 3
      • Slide the opening pick to the bottom right corner of the phone.
      • Insert a second opening pick and slide it to the bottom left corner of the phone.
      Ask FixBot
    5. Upper Main Flex Connector Disconnect Procedure: step 5, image 1 of 3 Upper Main Flex Connector Disconnect Procedure: step 5, image 2 of 3 Upper Main Flex Connector Disconnect Procedure: step 5, image 3 of 3
      • Slide the opening pick around the bottom left corner and then up along the left edge of the phone to open the plastic clamps that secure the backcover.
      Ask FixBot
    6. Upper Main Flex Connector Disconnect Procedure: step 6, image 1 of 3 Upper Main Flex Connector Disconnect Procedure: step 6, image 2 of 3 Upper Main Flex Connector Disconnect Procedure: step 6, image 3 of 3
      • Slide the opening pick around the bottom right corner and then up along the right edge of the phone to open the plastic clamps that secure the backcover.
      Ask FixBot
    7. Upper Main Flex Connector Disconnect Procedure: step 7, image 1 of 3 Upper Main Flex Connector Disconnect Procedure: step 7, image 2 of 3 Upper Main Flex Connector Disconnect Procedure: step 7, image 3 of 3
      • Try not to remove the backcover all the way yet. The fingerprint and the charging port and headphone flex cables are still connected to the motherboard.
      • Flip your phone and carefully lift the bottom end of the backcover away from the phone assembly. Fold it to left and hold it at an 80° angle.
      Ask FixBot
    8. Upper Main Flex Connector Disconnect Procedure: step 8, image 1 of 2 Upper Main Flex Connector Disconnect Procedure: step 8, image 2 of 2
      • Use a spudger to pry up and disconnect the fingerprint flex cable.
      Ask FixBot
    9. Upper Main Flex Connector Disconnect Procedure: step 9, image 1 of 3 Upper Main Flex Connector Disconnect Procedure: step 9, image 2 of 3 Upper Main Flex Connector Disconnect Procedure: step 9, image 3 of 3
      • Twist the backcover around 180° and lay it down to align the bottom end of the backcover the top edge of the battery.
      Ask FixBot
    10. Upper Main Flex Connector Disconnect Procedure: step 10, image 1 of 3 Upper Main Flex Connector Disconnect Procedure: step 10, image 2 of 3 Upper Main Flex Connector Disconnect Procedure: step 10, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of tweezers to remove the small metal shield which covers the battery and the charging port and headphone jack flex cable connectors.
      Ask FixBot
    11. Upper Main Flex Connector Disconnect Procedure: step 11, image 1 of 2 Upper Main Flex Connector Disconnect Procedure: step 11, image 2 of 2
      • Use a spudger to pry up and disconnect the charging port and headphone jack flex cable.
      Ask FixBot
    12. Upper Main Flex Connector Disconnect Procedure: step 12, image 1 of 2 Upper Main Flex Connector Disconnect Procedure: step 12, image 2 of 2
      • Remove the backcover.
      Ask FixBot
    1. Upper Main Flex Connector Disconnect Procedure, Battery Disconnect: step 13, image 1 of 2 Upper Main Flex Connector Disconnect Procedure, Battery Disconnect: step 13, image 2 of 2
      • Use a spudger to pry up and disconnect the battery flex cable.
      Ask FixBot
    1. Upper Main Flex Connector Disconnect Procedure, Upper Main Flex Connector Disconnect: step 14, image 1 of 3 Upper Main Flex Connector Disconnect Procedure, Upper Main Flex Connector Disconnect: step 14, image 2 of 3 Upper Main Flex Connector Disconnect Procedure, Upper Main Flex Connector Disconnect: step 14, image 3 of 3
      Buy
      • Use a pair of tweezers to unhinge and remove the small metal shield that covers the main and interconnect flex cable connectors.
      • The metal shield is held in place by mild adhesive. In case you're having trouble removing it, you can apply a heated iOpener to loosen the adhesive underneath.
      Ask FixBot
    2. Upper Main Flex Connector Disconnect Procedure: step 15, image 1 of 2 Upper Main Flex Connector Disconnect Procedure: step 15, image 2 of 2
      • Use a spudger to pry up and disconnect the main flex cable.
      Ask FixBot
Dominik Schnabelrauch
265,774 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 287
