Introduction
After a few weeks of use, some keys of my Zenbook keyboard became unresponsive. In my case, it was the vertical key rows. After opening my laptop I noticed the cable was unlocked. This guide will show you how to reconnect it.
This fix may not work in every scenario and is not guaranteed to work. This is a noninvasive fix you can try before sending the laptop out for repair or buying a new palmrest assembly.
Note: These 2 screws are longer then the others. Sort them accordingly.
Unscrew the remaining 8 screws. These are all the same length.
Remove the back cover. There are no warranty stickers that need to be broken.
Locate the keyboard connector. It is covered with a piece of tape helping hold it in place. This tape often fails after a certain amount of time.
You may need to remove the battery to disconnect it. Unscrew the 3 screws holding the battery in the system.
Remove the tape covering the connector. Note: New tape should be added once reseated.
Here on the picture you can see the connector in the unlocked position. These hold the connector in and should be completely pushed in.
Push the connector in. Do this until it is secure.
Lock the tabs that retain the keyboard connector in place.
