Shop the Holiday Gift Guide
Trackpad Prereq
View statistics:
Past 24 Hours:
0
Past 7 Days:
6
Past 30 Days:
26
All Time:
223
Comments: 10
10 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 40 minutes
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Trackpad Prereq
Introduction
Go to step 1 ↓
Trackpad prerequisite without the reassembly bullet.
Parts
Tools
    1. Trackpad Prereq, Remove the trackpad connector screws: step 1, image 1 of 1
      • Use a T3 Torx driver to remove the two 1.8 mm screws securing the trackpad cable connector bracket.
      Ask FixBot
    2. Trackpad Prereq: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the trackpad cable connector bracket with a pair of tweezers.
      Ask FixBot
    3. Trackpad Prereq, Disconnect the trackpad: step 3, image 1 of 2 Trackpad Prereq, Disconnect the trackpad: step 3, image 2 of 2
      • Use a spudger to disconnect the trackpad ribbon cable by gently prying its connector straight up from the logic board.
      Ask FixBot
    4. Trackpad Prereq, Heat the trackpad cable: step 4, image 1 of 1
      • Prepare an iOpener and lay it on top of the trackpad ribbon cable for about a minute, in order to soften the adhesive securing the trackpad ribbon cable to the top of the battery.
      • If you don't have an iOpener, use a hair dryer to warm up the cable instead. The cable should be warm, but not too hot to touch. Be careful not to overheat the battery.
      Ask FixBot
    5. Trackpad Prereq, Peel up the trackpad cable: step 5, image 1 of 3 Trackpad Prereq, Peel up the trackpad cable: step 5, image 2 of 3 Trackpad Prereq, Peel up the trackpad cable: step 5, image 3 of 3
      • Carefully peel the trackpad ribbon cable up off the battery, and push it out of the way.
      • Do not fold or tear the cable.
      Ask FixBot
    6. Trackpad Prereq, Remove the trackpad screws: step 6, image 1 of 1
      • Use a T5 Torx driver to remove the ten screws securing the trackpad assembly:
      • Two 4.3 mm screws
      • Eight 5.8 mm screws
      Ask FixBot
    7. Trackpad Prereq: step 7, image 1 of 2 Trackpad Prereq: step 7, image 2 of 2
      • Swing the display open slightly to access the trackpad.
      • Carefully thread the trackpad ribbon cable out through the hole in the MacBook Pro's frame.
      Ask FixBot
    8. Trackpad Prereq: step 8, image 1 of 3 Trackpad Prereq: step 8, image 2 of 3 Trackpad Prereq: step 8, image 3 of 3
      • Remove the trackpad assembly.
      • Be sure not to lose the six small washers (two circular and four rectangular) resting on the underside of the trackpad.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
Author
with
Tarun Thiruma
41,048 Reputation
133 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 26
All Time: 223
