Trackpad Prereq
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Trackpad Prereq, Remove the trackpad: step 1, image 1 of 1
    • Use a T5 Torx driver to remove the two 1.9 mm screws securing the trackpad cable connector bracket.
  2. Trackpad Prereq: step 2, image 1 of 1
    • Remove the trackpad cable connector bracket.
  3. Trackpad Prereq: step 3, image 1 of 2 Trackpad Prereq: step 3, image 2 of 2
    • Use a spudger to disconnect the trackpad ribbon cable by gently prying its connector straight up from the logic board.
  4. Trackpad Prereq: step 4, image 1 of 1
    • Prepare an iOpener and lay it on top of the trackpad ribbon cable for about a minute, in order to soften the adhesive securing the trackpad ribbon cable to the top of the battery.
    • If you don't have an iOpener, use a hair dryer to warm up the cable instead. The cable should be warm, but not too hot to touch. Be careful not to overheat the battery.
  5. Trackpad Prereq: step 5, image 1 of 3 Trackpad Prereq: step 5, image 2 of 3 Trackpad Prereq: step 5, image 3 of 3
    • Carefully peel the trackpad ribbon cable up off the battery, and push it out of the way.
    • Do not fold or tear the cable.
  6. Trackpad Prereq: step 6, image 1 of 1
    • Use a T5 Torx driver to remove the ten screws securing the trackpad assembly:
    • Two 4.3 mm screws
    • Eight 5.8 mm screws
  7. Trackpad Prereq: step 7, image 1 of 3 Trackpad Prereq: step 7, image 2 of 3 Trackpad Prereq: step 7, image 3 of 3
    • Remove the trackpad assembly.
    • You'll need to swing the display open slightly to remove the trackpad.
    • Take care to feed the trackpad ribbon cable through the MacBook Pro's frame without snagging.
    • Be sure not to lose the six small washers (two circular and four rectangular) resting on the underside of the trackpad.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
Carsten Frauenheim
155,971 Reputation
439 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,784 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 73
