Introduction
Screen replacement for this laptop is simple and only requires a screwdriver and a plastic opening tool.
Begin by removing the battery and flipping the laptop over to see the screws
Using a phillips head screwdriver to remove the screws that secure the back
Flip the laptop back over and open it up carefully
Lift up the bottom panel where the mouse click buttons are
Using the spudger disconnect the ribbon cable connected to the bottom of the panel
Using the same size phillips as before remove the two screws that hold the keyboard in place
Then simply lift the keyboard up and slide it down and out
Using the phillips remove the 3 screws that hold the screen mount to the rest of the keyboard
Pull the screen off the rest of the laptop and flip it over
Using the phillips screw driver remove the final 3 screws securing the screen
