Toshiba Portege 3110CT Laptop Screen Replacement
  1. Toshiba Portege 3110CT Laptop Screen Replacement, Laptop Screen: step 1, image 1 of 1
    • Begin by removing the battery and flipping the laptop over to see the screws
    • Using a phillips head screwdriver to remove the screws that secure the back
  2. Toshiba Portege 3110CT Laptop Screen Replacement: step 2, image 1 of 1
    • Flip the laptop back over and open it up carefully
    • Lift up the bottom panel where the mouse click buttons are
    • Lift up slowly as simply flip it up and rest it on the keyboard as not to damage the ribbon cable connecting it
    • Using the spudger disconnect the ribbon cable connected to the bottom of the panel
  3. Toshiba Portege 3110CT Laptop Screen Replacement: step 3, image 1 of 1
    • Using the same size phillips as before remove the two screws that hold the keyboard in place
    • Then simply lift the keyboard up and slide it down and out
  4. Toshiba Portege 3110CT Laptop Screen Replacement: step 4, image 1 of 1
    • Using the phillips remove the 3 screws that hold the screen mount to the rest of the keyboard
    • Once you remove the final screw be careful as the screen will want to fall back to prevent damage
  5. Toshiba Portege 3110CT Laptop Screen Replacement: step 5, image 1 of 1
    • Pull the screen off the rest of the laptop and flip it over
    • Using the phillips screw driver remove the final 3 screws securing the screen
Ashley Furtado
101 Reputation
1 Guide authored
UMass Dartmouth, Team 6-4, Martin Fall 2016 Member of UMass Dartmouth, Team 6-4, Martin Fall 2016
UMASSD-MARTIN-F16S6G4
3 Members
15 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 429
