Shop the Holiday Gift Guide
Top Vibrator Bracket
View statistics:
Past 24 Hours:
Past 7 Days:
5
Past 30 Days:
17
All Time:
262
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prereq for top bracket with the vibrator.
Tools
    1. Top Vibrator Bracket, Safety Precautions: step 1, image 1 of 1
      • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
      • Fully power off your phone and unplug any cables.
      Ask FixBot
    1. Top Vibrator Bracket, Heat the bottom edge: step 2, image 1 of 1
      • Heat an iOpener and apply it to the bottom edge of the screen for two minutes.
      Ask FixBot
    2. Top Vibrator Bracket, Adhesive information: step 3, image 1 of 2 Top Vibrator Bracket, Adhesive information: step 3, image 2 of 2
      • While you're waiting for the adhesive to soften, note the following:
      • The adhesive is under the dark black border surrounding the screen.
      • During the screen removal procedure, you only need to insert your opening pick as deep as the border.
      • Don't insert your pick any deeper, as you risk damaging the screen and internal components.
      Ask FixBot
    3. Top Vibrator Bracket, Insert an opening pick: step 4, image 1 of 3 Top Vibrator Bracket, Insert an opening pick: step 4, image 2 of 3 Top Vibrator Bracket, Insert an opening pick: step 4, image 3 of 3
      • Apply a suction cup to the screen, as close to the center of the bottom edge as possible.
      • Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
      • Insert an opening pick into the gap.
      • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
      • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the screen.
      Ask FixBot
    4. Top Vibrator Bracket, Separate the bottom adhesive: step 5, image 1 of 3 Top Vibrator Bracket, Separate the bottom adhesive: step 5, image 2 of 3 Top Vibrator Bracket, Separate the bottom adhesive: step 5, image 3 of 3
      • Slide the opening pick along the bottom edge to separate the adhesive.
      • Leave the opening pick in the bottom right corner before continuing.
      Ask FixBot
    5. Top Vibrator Bracket, Heat the right edge: step 6, image 1 of 1
      • Apply a heated iOpener to the right edge of the screen for two minutes.
      Ask FixBot
    6. Top Vibrator Bracket, Separate the bottom right adhesive: step 7, image 1 of 2 Top Vibrator Bracket, Separate the bottom right adhesive: step 7, image 2 of 2
      • Rotate the opening pick around the bottom right corner to separate the adhesive.
      Ask FixBot
    7. Top Vibrator Bracket, Separate the right adhesive: step 8, image 1 of 3 Top Vibrator Bracket, Separate the right adhesive: step 8, image 2 of 3 Top Vibrator Bracket, Separate the right adhesive: step 8, image 3 of 3
      • Insert a new opening pick in the bottom right corner.
      • Slide the opening pick toward the top right corner to separate the adhesive.
      • Leave the opening pick in the top right corner before continuing.
      Ask FixBot
    8. Top Vibrator Bracket, Heat the top edge: step 9, image 1 of 1
      • Apply a heated iOpener to the top edge of the screen for two minutes.
      Ask FixBot
    9. Top Vibrator Bracket, Separate the top right adhesive: step 10, image 1 of 2 Top Vibrator Bracket, Separate the top right adhesive: step 10, image 2 of 2
      • Rotate the opening pick around the top right corner to separate its adhesive.
      Ask FixBot
    10. Top Vibrator Bracket, Separate the top adhesive: step 11, image 1 of 2 Top Vibrator Bracket, Separate the top adhesive: step 11, image 2 of 2
      • Insert a new opening pick in the top right corner.
      • Slide the opening pick toward the top left corner to separate its adhesive.
      Ask FixBot
    11. Top Vibrator Bracket, Heat the left edge: step 12, image 1 of 1
      • Apply a heated iOpener to the left edge of the screen for two minutes.
      Ask FixBot
    12. Top Vibrator Bracket, Separate the top left adhesive: step 13, image 1 of 2 Top Vibrator Bracket, Separate the top left adhesive: step 13, image 2 of 2
      • The sharp corner is very fragile. Use plenty of heat and be very gentle around the corner during this step.
      • Angle your pick so it's as flat as possible to the screen.
      • Rotate the opening pick around the top left corner to separate the adhesive.
      Ask FixBot
    13. Top Vibrator Bracket, Separate the left adhesive: step 14, image 1 of 3 Top Vibrator Bracket, Separate the left adhesive: step 14, image 2 of 3 Top Vibrator Bracket, Separate the left adhesive: step 14, image 3 of 3
      • Insert a new opening pick in the top left corner.
      • Slide the opening pick toward the bottom left corner to separate the adhesive.
      Ask FixBot
    14. Top Vibrator Bracket, Separate the bottom left adhesive: step 15, image 1 of 2 Top Vibrator Bracket, Separate the bottom left adhesive: step 15, image 2 of 2
      • Rotate the opening pick around the bottom left corner to separate the adhesive.
      Ask FixBot
    15. Top Vibrator Bracket, Adhesive information: step 16, image 1 of 1
      • There's a small adhesive strip that secures the screen near the top right corner of the phone.
      • The next three steps will show you how to separate this adhesive.
      Ask FixBot
    16. Top Vibrator Bracket, Heat the top right corner: step 17, image 1 of 1
      • Heat an iOpener and apply it to the top right corner of the screen for two minutes.
      Ask FixBot
    17. Top Vibrator Bracket, Insert an opening pick: step 18, image 1 of 3 Top Vibrator Bracket, Insert an opening pick: step 18, image 2 of 3 Top Vibrator Bracket, Insert an opening pick: step 18, image 3 of 3
      • Insert an opening pick under the right edge of the screen, near the top right corner.
      • Push the opening pick under the screen as far you can go without losing your grip.
      Ask FixBot
    18. Top Vibrator Bracket, Separate the adhesive: step 19, image 1 of 2 Top Vibrator Bracket, Separate the adhesive: step 19, image 2 of 2
      • Be very careful during this step, as you risk breaking the screen. Work slowly and apply more heat if necessary.
      • Twist the opening pick back and forth to separate the adhesive.
      • If you don't feel the adhesive separating, apply more heat or insert the pick at a different angle.
      Ask FixBot
    19. Top Vibrator Bracket, Reposition the screen: step 20, image 1 of 3 Top Vibrator Bracket, Reposition the screen: step 20, image 2 of 3 Top Vibrator Bracket, Reposition the screen: step 20, image 3 of 3
      • At this point, the screen should be separated from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
      • Don't remove the screen yet, as it's still connected to the phone by a cable.
      • Swing the left edge of the screen up and over the right edge of the phone.
      • Let the screen rest next to the phone before continuing.
      Ask FixBot
    20. Top Vibrator Bracket, Unfasten the bottom bracket: step 21, image 1 of 1
      Tool used on this step:
      FixMat
      $36.95
      Buy
      • While the Pixel Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 Torx or T4 bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
      • Use a Torx Plus 3IP screwdriver to remove the five 2.5 mm‑long screws securing the bottom bracket.
      Ask FixBot
    21. Top Vibrator Bracket, Remove the bottom bracket: step 22, image 1 of 2 Top Vibrator Bracket, Remove the bottom bracket: step 22, image 2 of 2
      Buy
      • Use tweezers, or your fingers, to remove the bottom bracket.
      • During reassembly, make sure the bottom bracket is sitting in its two alignment pegs before refastening it.
      Ask FixBot
    22. Top Vibrator Bracket, Disconnect the flip battery: step 23, image 1 of 2 Top Vibrator Bracket, Disconnect the flip battery: step 23, image 2 of 2
      • Don't pry against the battery during this step. Angle your spudger under the left or right edges of the press connector.
      • Use the flat end of a spudger to pry up and disconnect the flip battery press connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Ask FixBot
    23. Top Vibrator Bracket, Disconnect the screen: step 24, image 1 of 2 Top Vibrator Bracket, Disconnect the screen: step 24, image 2 of 2
      • Insert the point of a spudger under the short edge of the screen press connector facing the bottom of the phone.
      • Don't insert your spudger anywhere else, as you risk damaging surface-mounted components on the logic board.
      • Pry up to disconnect the screen press connector.
      Ask FixBot
    24. Top Vibrator Bracket, Remove the screen: step 25, image 1 of 1
      • Remove the screen.
      • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
      • To prevent damaging your screen or replacement screen:
      • When handling your screen, grip it by its edges.
      • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
      Ask FixBot
    25. Top Vibrator Bracket, Reassembly information: step 26, image 1 of 3 Top Vibrator Bracket, Reassembly information: step 26, image 2 of 3 Top Vibrator Bracket, Reassembly information: step 26, image 3 of 3
      Tesa 61395 Tape
      $8.95
      Buy
      • During reassembly, perform the following:
      • If you're reusing your screen, use tweezers to remove big chunks of adhesive from the perimeter of the screen.
      • Repeat for any adhesive on the frame, including the small adhesive at the top right of the phone.
      • If your top right adhesive is still intact and sticky, you can reuse it.
      • Use isopropyl alcohol (>90%) and a lint-free cloth to remove any remaining adhesive residue.
      • Follow this guide to replace your screen adhesive.
      • If you don't have custom cut adhesive strips, use double-sided tape, like Tesa Tape, to secure the screen to the frame.
      Ask FixBot
    1. Top Vibrator Bracket, Unfasten the top bracket: step 27, image 1 of 2 Top Vibrator Bracket, Unfasten the top bracket: step 27, image 2 of 2
      Buy
      • Use a Torx Plus 3IP screwdriver to remove the three 2.5 mm‑long screws securing the top bracket.
      • There's a magnet at the top right corner of phone. As you remove nearby screws, they might stick the magnet.
      • If you're having trouble inserting these screws, use tweezers to hold it in place while you screw in the first few threads.
      Ask FixBot
    2. Top Vibrator Bracket, Remove the top bracket: step 28, image 1 of 3 Top Vibrator Bracket, Remove the top bracket: step 28, image 2 of 3 Top Vibrator Bracket, Remove the top bracket: step 28, image 3 of 3
      • The flip vibrator is attached to the underside of the top bracket.
      • Pull the top bracket toward the left edge of the phone to separate it from its recess in the frame.
      • Remove the top bracket.
      • During reassembly, insert the right edge of the top bracket under its lip in the frame before aligning the screw holes.
      Ask FixBot
Author
with
Alex Diaz-Kokaisl
252,773 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,189 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 17
All Time: 262
