Introduction
The front cover can get chipped or scratched. In this case it should be replaced.
Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
Next, you must remove the motherboard from the front screen.
Use a Torx T-7 screwdriver to unscrew the two screws.
Before you can seperate the motherboard from the front cover, you must disconnect the wire connecting the two.
To do so, you must use the back end of the spudger to push out the two white tabs connected to the wire, that holds the motherboard and front cover together.
Apply pressure with thumbs to remove screen from inner casing.
The screen and front cover are now disconnected.
