Repairing TomTom ONE Front Cover
  1. Repairing TomTom ONE Front Cover, Screen: step 1, image 1 of 1
    • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
  2. Repairing TomTom ONE Front Cover: step 2, image 1 of 2 Repairing TomTom ONE Front Cover: step 2, image 2 of 2
    • Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
  3. Repairing TomTom ONE Front Cover: step 3, image 1 of 1
    • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
  4. Repairing TomTom ONE Front Cover: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Once the two covers are separated, use the tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
  5. Repairing TomTom ONE Front Cover: step 5, image 1 of 1
    • Next, you must remove the motherboard from the front screen.
    • Use a Torx T-7 screwdriver to unscrew the two screws.
  6. Repairing TomTom ONE Front Cover: step 6, image 1 of 2 Repairing TomTom ONE Front Cover: step 6, image 2 of 2
    • Before you can seperate the motherboard from the front cover, you must disconnect the wire connecting the two.
    • To do so, you must use the back end of the spudger to push out the two white tabs connected to the wire, that holds the motherboard and front cover together.
  7. Repairing TomTom ONE Front Cover: step 7, image 1 of 1
    • Once separated, use the spudger to pry around the edges of the outer casing.
  8. Repairing TomTom ONE Front Cover: step 8, image 1 of 2 Repairing TomTom ONE Front Cover: step 8, image 2 of 2
    • Apply pressure with thumbs to remove screen from inner casing.
    • The screen and front cover are now disconnected.
Trevor Foster
145 Reputation
3 Guides authored
Cal Poly, Team 7-7, Maness Spring 2010 Member of Cal Poly, Team 7-7, Maness Spring 2010
CPSU-MANESS-S10S7G7
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 4,278
