Steam Machine (2026) RAM Replacement
    1. Steam Machine (2026) RAM Replacement, Before you begin: step 1, image 1 of 3 Steam Machine (2026) RAM Replacement, Before you begin: step 1, image 2 of 3 Steam Machine (2026) RAM Replacement, Before you begin: step 1, image 3 of 3
      • Before you begin this repair:
      • Power down your Steam Machine and disconnect the power cable.
      • Unplug any remaining cables or accessories from all ports.
      • If you have a microSD card installed, remove it. Otherwise, it may break during this procedure.
      Ask FixBot
    1. Steam Machine (2026) RAM Replacement, Reposition the Steam Machine: step 2, image 1 of 1
      • Reposition the Steam Machine so the bottom is facing up.
      Ask FixBot
    2. Steam Machine (2026) RAM Replacement, Remove the feet: step 3, image 1 of 3 Steam Machine (2026) RAM Replacement, Remove the feet: step 3, image 2 of 3 Steam Machine (2026) RAM Replacement, Remove the feet: step 3, image 3 of 3
      • Use a T8 Torx screwdriver to remove the four rubber feet.
      Ask FixBot
    1. Steam Machine (2026) RAM Replacement, Reposition the Steam Machine: step 4, image 1 of 1
      • Reposition the Steam Machine so the back panel is facing up.
      Ask FixBot
    2. Steam Machine (2026) RAM Replacement, Loosen the back panel screws: step 5, image 1 of 2 Steam Machine (2026) RAM Replacement, Loosen the back panel screws: step 5, image 2 of 2
      • Use a T8 Torx screwdriver to fully loosen the two captive screws securing the back panel.
      Ask FixBot
    3. Steam Machine (2026) RAM Replacement, Remove the back panel: step 6, image 1 of 3 Steam Machine (2026) RAM Replacement, Remove the back panel: step 6, image 2 of 3 Steam Machine (2026) RAM Replacement, Remove the back panel: step 6, image 3 of 3
      • The back panel is secured by two hinge clips near the bottom corners and two locking clips on the sides.
      • Lift the top edge of the panel (near the screws) until the two locking clips release.
      • If you're having trouble getting an initial grip on the panel, use a spudger to lift it enough to grab with your fingers.
      • Slide the panel towards the top edge and lift to remove it.
      Ask FixBot
    4. Steam Machine (2026) RAM Replacement, Remove the inner assembly screws: step 7, image 1 of 2 Steam Machine (2026) RAM Replacement, Remove the inner assembly screws: step 7, image 2 of 2
      • Use a T8 Torx screwdriver to remove the two 7.3 mm‑long screws securing the inner assembly.
      Ask FixBot
    5. Steam Machine (2026) RAM Replacement, Remove the inner assembly: step 8, image 1 of 3 Steam Machine (2026) RAM Replacement, Remove the inner assembly: step 8, image 2 of 3 Steam Machine (2026) RAM Replacement, Remove the inner assembly: step 8, image 3 of 3
      • After removal, don't lay the inner assembly down on the microSD and USB ports. These ports are fragile and shouldn't have the weight of the assembly resting on them.
      • Grip the inner assembly under the fan and lift it straight up and out of the shell.
      • Set the inner assembly down so the SSD is on top.
      Ask FixBot
    1. Steam Machine (2026) RAM Replacement, Reposition the inner assembly: step 9, image 1 of 1
      • Spin the inner assembly so the fan faces you.
      Ask FixBot
    2. Steam Machine (2026) RAM Replacement, Remove the cable cover screws: step 10, image 1 of 2 Steam Machine (2026) RAM Replacement, Remove the cable cover screws: step 10, image 2 of 2
      • Use a T8 Torx screwdriver to remove the 5.1 mm‑long screw securing the rear USB and Ethernet port cable cover.
      Ask FixBot
    3. Steam Machine (2026) RAM Replacement, Remove the cable cover: step 11, image 1 of 2 Steam Machine (2026) RAM Replacement, Remove the cable cover: step 11, image 2 of 2
      • Remove the cable cover.
      • During reassembly, make sure the tab on the edge of the cable cover slides into its cutout in the fan.
      Ask FixBot
    4. Steam Machine (2026) RAM Replacement, Disconnect the board: step 12, image 1 of 2 Steam Machine (2026) RAM Replacement, Disconnect the board: step 12, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the board's press connector.
      Ask FixBot
    5. Steam Machine (2026) RAM Replacement, Remove the board screw: step 13, image 1 of 2 Steam Machine (2026) RAM Replacement, Remove the board screw: step 13, image 2 of 2
      • Use a T8 Torx screwdriver to remove the 5.1 mm‑long screw securing the rear USB and Ethernet port board.
      Ask FixBot
    6. Steam Machine (2026) RAM Replacement, Remove the board: step 14, image 1 of 2 Steam Machine (2026) RAM Replacement, Remove the board: step 14, image 2 of 2
      • Slide the board straight away fron the inner assembly to remove it.
      Ask FixBot
    1. Steam Machine (2026) RAM Replacement, Reposition the inner assembly: step 15, image 1 of 2 Steam Machine (2026) RAM Replacement, Reposition the inner assembly: step 15, image 2 of 2
      • Reposition the inner assembly so the antenna marked AUX ANT is facing up.
      Ask FixBot
    2. Steam Machine (2026) RAM Replacement, Heat the auxiliary antenna: step 16, image 1 of 3 Steam Machine (2026) RAM Replacement, Heat the auxiliary antenna: step 16, image 2 of 3 Steam Machine (2026) RAM Replacement, Heat the auxiliary antenna: step 16, image 3 of 3
      • Mild adhesive secures the auxiliary antenna to the fan. Heating the antenna softens the adhesive, making it easier to separate. If you don't want to remove the antennas from the fan, you can disconnect and de-route them.
      • Lay a heated iOpener on the auxiliary antenna for two minutes.
      • Check out this guide for instruction on heating an iOpener.
      • Alternatively, you can use a hair dryer to soften the adhesive. For tips on using a hair dryer without accidentally melting plastic, check out this guide.
      Ask FixBot
    3. Steam Machine (2026) RAM Replacement, Separate the auxiliary antenna: step 17, image 1 of 3 Steam Machine (2026) RAM Replacement, Separate the auxiliary antenna: step 17, image 2 of 3 Steam Machine (2026) RAM Replacement, Separate the auxiliary antenna: step 17, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • Slide the flat end of a spudger under the antenna and lift to separate the adhesive.
      • During reassembly, the adhesive should be sticky enough to reuse. If it isn't, use thin double-sided tape to secure the antenna.
      Ask FixBot
    4. Steam Machine (2026) RAM Replacement, De-route the auxiliary antenna: step 18, image 1 of 3 Steam Machine (2026) RAM Replacement, De-route the auxiliary antenna: step 18, image 2 of 3 Steam Machine (2026) RAM Replacement, De-route the auxiliary antenna: step 18, image 3 of 3
      • Guide the antenna cable out of its clips on the fan.
      Ask FixBot
    5. Steam Machine (2026) RAM Replacement, Reposition the inner assembly: step 19, image 1 of 2 Steam Machine (2026) RAM Replacement, Reposition the inner assembly: step 19, image 2 of 2
      • Reposition the inner assembly so the antenna marked MAIN ANT is facing up.
      Ask FixBot
    6. Steam Machine (2026) RAM Replacement, Heat the main antenna: step 20, image 1 of 3 Steam Machine (2026) RAM Replacement, Heat the main antenna: step 20, image 2 of 3 Steam Machine (2026) RAM Replacement, Heat the main antenna: step 20, image 3 of 3
      • Mild adhesive secures the main antenna to the fan. Heating the antenna softens the adhesive, making it easier to separate.
      • Lay a heated iOpener on the main antenna for two minutes.
      Ask FixBot
    7. Steam Machine (2026) RAM Replacement, Separate the main antenna: step 21, image 1 of 3 Steam Machine (2026) RAM Replacement, Separate the main antenna: step 21, image 2 of 3 Steam Machine (2026) RAM Replacement, Separate the main antenna: step 21, image 3 of 3
      Tesa 61395 Tape
      $2.95
      Buy
      Ask FixBot
    8. Steam Machine (2026) RAM Replacement, De-route the main antenna: step 22, image 1 of 3 Steam Machine (2026) RAM Replacement, De-route the main antenna: step 22, image 2 of 3 Steam Machine (2026) RAM Replacement, De-route the main antenna: step 22, image 3 of 3
      • Guide the antenna cable out of its plastic clips.
      Ask FixBot
    9. Steam Machine (2026) RAM Replacement, Disconnect the fan: step 23, image 1 of 3 Steam Machine (2026) RAM Replacement, Disconnect the fan: step 23, image 2 of 3 Steam Machine (2026) RAM Replacement, Disconnect the fan: step 23, image 3 of 3
      • The fan connector can be tricky to disconnect. Be careful: excessive force could rip the socket off the board.
      • Use a pair of angled tweezers to firmly grip the head of the fan cable connector.
      • To get the best grip, hold the tweezers close to the pointed ends.
      • Gently rock the connector side-to-side while lifting to disconnect it.
      Ask FixBot
    10. Steam Machine (2026) RAM Replacement, Peel up the fan cable: step 24, image 1 of 2 Steam Machine (2026) RAM Replacement, Peel up the fan cable: step 24, image 2 of 2
      • Peel up the tape securing the fan cable to the heatsink.
      Ask FixBot
    11. Steam Machine (2026) RAM Replacement, Reposition the inner assembly: step 25, image 1 of 1
      • Reposition the inner assembly so the fan is facing you and the power cable socket is on the bottom.
      Ask FixBot
    12. Steam Machine (2026) RAM Replacement, Remove the fan screws: step 26, image 1 of 2 Steam Machine (2026) RAM Replacement, Remove the fan screws: step 26, image 2 of 2
      • Use a T8 Torx screwdriver to remove the two 7.3 mm‑long screws securing the fan.
      Ask FixBot
    13. Steam Machine (2026) RAM Replacement, Remove the fan: step 27, image 1 of 2 Steam Machine (2026) RAM Replacement, Remove the fan: step 27, image 2 of 2
      • Slide the fan straight away from the inner assembly to remove it.
      • During reassembly, make sure no cables get stuck behind the fan when sliding it back in place.
      Ask FixBot
    1. Steam Machine (2026) RAM Replacement, Reposition the inner assembly: step 28, image 1 of 1
      • Reposition the inner assembly so the microSD reader and two USB ports are facing up at the top edge farthest from you.
      Ask FixBot
    2. Steam Machine (2026) RAM Replacement, Remove the cable cover screws: step 29, image 1 of 2 Steam Machine (2026) RAM Replacement, Remove the cable cover screws: step 29, image 2 of 2
      • Use a T8 Torx screwdriver to remove the two 5.1 mm‑long screws securing the front port cable cover.
      Ask FixBot
    3. Steam Machine (2026) RAM Replacement, Remove the cable cover: step 30, image 1 of 2 Steam Machine (2026) RAM Replacement, Remove the cable cover: step 30, image 2 of 2
      Ask FixBot
    4. Steam Machine (2026) RAM Replacement, Disconnect the front port board: step 31, image 1 of 2 Steam Machine (2026) RAM Replacement, Disconnect the front port board: step 31, image 2 of 2
      Ask FixBot
    5. Steam Machine (2026) RAM Replacement: step 32, image 1 of 3 Steam Machine (2026) RAM Replacement: step 32, image 2 of 3 Steam Machine (2026) RAM Replacement: step 32, image 3 of 3
      • Use the point of a spudger to lift and disconnect the three coaxial connectors, making sure to lift as close to the connector head as possible.
      Ask FixBot
    6. Steam Machine (2026) RAM Replacement, Reposition the inner assembly: step 33, image 1 of 1
      • Reposition the inner assembly so the microSD and two USB ports are at the top edge closest to you.
      Ask FixBot
    7. Steam Machine (2026) RAM Replacement, Remove the cable cover screws: step 34, image 1 of 2 Steam Machine (2026) RAM Replacement, Remove the cable cover screws: step 34, image 2 of 2
      • Use a T8 Torx screwdriver to remove the two 5.1 mm‑long screws securing the HDMI and DisplayPort cable cover.
      Ask FixBot
    8. Steam Machine (2026) RAM Replacement, Remove the cable cover: step 35, image 1 of 2 Steam Machine (2026) RAM Replacement, Remove the cable cover: step 35, image 2 of 2
      Ask FixBot
    9. Steam Machine (2026) RAM Replacement, Disconnect the board: step 36, image 1 of 2 Steam Machine (2026) RAM Replacement, Disconnect the board: step 36, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the press connector on the HDMI and DisplayPort board.
      Ask FixBot
    10. Steam Machine (2026) RAM Replacement, Separate the cable: step 37, image 1 of 2 Steam Machine (2026) RAM Replacement, Separate the cable: step 37, image 2 of 2
      • Use your fingers to gently peel the HDMI and DisplayPort board's cable off the metal frame.
      • If you're having trouble, use an iOpener or hair dryer to heat the cable.
      Ask FixBot
    11. Steam Machine (2026) RAM Replacement, Remove the SSD screw: step 38, image 1 of 2 Steam Machine (2026) RAM Replacement, Remove the SSD screw: step 38, image 2 of 2
      • Use a T8 Torx screwdriver to remove the 5.1 mm‑long screw securing the SSD.
      • With the screw removed, the SSD will pop up at a shallow angle.
      Ask FixBot
    12. Steam Machine (2026) RAM Replacement, Remove the SSD: step 39, image 1 of 2 Steam Machine (2026) RAM Replacement, Remove the SSD: step 39, image 2 of 2
      • Don't pull up on the SSD at a sharp angle, or you may damage the SSD and its socket.
      • Pull the SSD out of its socket at the angle it popped up at to remove it.
      Ask FixBot
    13. Steam Machine (2026) RAM Replacement, Remove the SSD board screws: step 40, image 1 of 2 Steam Machine (2026) RAM Replacement, Remove the SSD board screws: step 40, image 2 of 2
      • Use a T8 Torx screwdriver to remove the two 5.1 mm‑long screws securing the SSD board and its cover.
      • With the screws removed, the board is only attached by its ribbon cable.
      Ask FixBot
    14. Steam Machine (2026) RAM Replacement, Remove the SSD board cable cover: step 41, image 1 of 2 Steam Machine (2026) RAM Replacement, Remove the SSD board cable cover: step 41, image 2 of 2
      Ask FixBot
    15. Steam Machine (2026) RAM Replacement, Disconnect the SSD board: step 42, image 1 of 2 Steam Machine (2026) RAM Replacement, Disconnect the SSD board: step 42, image 2 of 2
      • With one hand, hold the board down by the SSD socket.
      • With your free hand, use the flat end of a spudger to pry up and disconnect the board's press connector.
      Ask FixBot
    16. Steam Machine (2026) RAM Replacement, Remove the SSD board: step 43, image 1 of 2 Steam Machine (2026) RAM Replacement, Remove the SSD board: step 43, image 2 of 2
      • Lift the SSD board straight up and remove it.
      Ask FixBot
    17. Steam Machine (2026) RAM Replacement, Separate the cable: step 44, image 1 of 2 Steam Machine (2026) RAM Replacement, Separate the cable: step 44, image 2 of 2
      • Use your fingers to gently peel the SSD board cable off the metal frame.
      • If you're having trouble, you can use an iOpener or hair dryer to heat the cable.
      Ask FixBot
    18. Steam Machine (2026) RAM Replacement, Reposition the inner assembly: step 45, image 1 of 1
      • Flip the inner assembly over so the heatsink is on top.
      Ask FixBot
    19. Steam Machine (2026) RAM Replacement, Remove the power supply screws: step 46, image 1 of 2 Steam Machine (2026) RAM Replacement, Remove the power supply screws: step 46, image 2 of 2
      • Use a T8 Torx screwdriver to remove the four 12.8 mm‑long screws securing the power supply.
      Ask FixBot
    20. Steam Machine (2026) RAM Replacement, Disconnect the power supply: step 47, image 1 of 3 Steam Machine (2026) RAM Replacement, Disconnect the power supply: step 47, image 2 of 3 Steam Machine (2026) RAM Replacement, Disconnect the power supply: step 47, image 3 of 3
      • The corner of the motherboard closest to the DisplayPort port has two metal prongs that connect it to the power supply.
      • With one hand, firmly secure the power supply.
      • With your free hand, grip under the corner of the inner assembly so you're lifting up on the motherboard itself.
      • Firmly pull the corner up until it disconnects from the power supply.
      • This requires some force and may take a few attempts.
      Ask FixBot
    21. Steam Machine (2026) RAM Replacement, Remove the motherboard and heatsink: step 48, image 1 of 3 Steam Machine (2026) RAM Replacement, Remove the motherboard and heatsink: step 48, image 2 of 3 Steam Machine (2026) RAM Replacement, Remove the motherboard and heatsink: step 48, image 3 of 3
      • Remove the motherboard and heatsink from the power supply and set it down so the motherboard is facing up.
      Ask FixBot
    1. Steam Machine (2026) RAM Replacement, Remove the RAM: step 49, image 1 of 3 Steam Machine (2026) RAM Replacement, Remove the RAM: step 49, image 2 of 3 Steam Machine (2026) RAM Replacement, Remove the RAM: step 49, image 3 of 3
      • Simultaneously push the RAM module's two metal arms outward to disengage them.
      • Remove the RAM.
      • To install a stick of RAM, slide it into its socket at a slight downward angle and push down firmly until both metal arms lock it in place.
      Ask FixBot
Spencer Day
205,151 Reputation
1,266 Guides authored
0 Guide Comments
Past 24 Hours: 367
Past 7 Days: 586
Past 30 Days: 600
All Time: 605
