OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓Use this guide to replace the action buttons (ABXY) and their membrane in your Steam Deck LCD.
Remember: follow general electrostatic discharge (ESD) safety procedures while repairing your device.
Note: Valve started shipping Steam Decks with refreshed internal designs in early 2023. Your Steam Deck may look different than the one depicted in the photos, but the procedure is the same. Remove the back cover to check what version you have. An original Steam Deck will have a metallic motherboard shield and a fan with square sides, as seen here. A refreshed Steam Deck will have a black motherboard shield and a fan with curved sides, as seen here.
Power down your Steam Deck and unplug any cables.
Tool used on this step:FixMat$36.95
Use a Phillips driver to remove the eight screws securing the back cover:
Four coarse thread 9.5 mm-long screws
Four fine thread 5.8 mm-long screws
Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
Pry up on the back cover to release it from the locking clips.
Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
Remove the back cover.
Tool used on this step:Tweezers$4.99
Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
Use a Phillips driver to remove the three screws securing the board shield:
One 3.4 mm screw
Two 3.7 mm screws
Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
Place the flat end of a spudger onto the inside edge of the trigger's right clip.
Pivot the trigger clip out, away, and up from the peg to unlatch it.
Use a Phillips driver to remove the three 5.2 mm screws securing the right trigger bracket.
Use the pointed end of a spudger to lift up the small locking flap on the thumbstick cable's ZIF connector.
Use a pair of tweezers to slide the cable out of its connector.
Use a Phillips driver to remove the three 5.2 mm screws securing the thumbstick.
Use the pointed end of a spudger to lift up the small locking flap on the button board cable's ZIF connector.
Use the pointed end of a spudger to lift up the small locking flap on the button board interconnect cable's ZIF connector.
If any connectors are covered with tape, use a pair of tweezers to remove it.
Use the pointed end of a spudger to lift up the small locking flaps on the rest of the button board ZIF connectors. Use a pair of tweezers to slide the cables out of their connectors:
Disconnect the action buttons cable.
Disconnect the touchpad board cable.
Disconnect the touchpad cable.
Use the pointed end of a spudger to lift up on the haptics cable to disconnect it.
Use a Phillips driver to disconnect the four screws securing the right button board:
Three 5.2 mm screws
One 3.9 mm screw
Use a Phillips driver to remove the two 5.2 mm screws securing the right bumper assembly.
Use a pair of tweezers to remove the action buttons membrane.
Use a pair of tweezers to remove the four action buttons, A, B, X, and Y.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
20 other people completed this guide.
10 Guide Comments
Is this action buttons membrane compatible with the OLED model? It looks the same but I want to be sure.
