Sony Xperia Z3 Compact Main Flex Replacement
  1. Sony Xperia Z3 Compact Main Flex Replacement, Main Flex: step 1, image 1 of 3 Sony Xperia Z3 Compact Main Flex Replacement, Main Flex: step 1, image 2 of 3 Sony Xperia Z3 Compact Main Flex Replacement, Main Flex: step 1, image 3 of 3
    • First, heat up.
    • And then place the suction cup and pull to open a gap. Insert into the guitar pick to cut the adhesive sticker under the back cover.
    • Finally, remove the back cover.
  2. Sony Xperia Z3 Compact Main Flex Replacement: step 2, image 1 of 3 Sony Xperia Z3 Compact Main Flex Replacement: step 2, image 2 of 3 Sony Xperia Z3 Compact Main Flex Replacement: step 2, image 3 of 3
    • Disconnect the NFC antenna.
    • Unscrew the screws holding the black midframe in place.
    • Remove back frame.
  3. Sony Xperia Z3 Compact Main Flex Replacement: step 3, image 1 of 3 Sony Xperia Z3 Compact Main Flex Replacement: step 3, image 2 of 3 Sony Xperia Z3 Compact Main Flex Replacement: step 3, image 3 of 3
    • Remove rear camera bracket.
    • Release connector, but take care not to damage the electronic components next to the connector. It is best to access the connector from the bottom (battery side), and not from the side as the picture shows.
    • Remove rear camera.
  4. Sony Xperia Z3 Compact Main Flex Replacement: step 4, image 1 of 3 Sony Xperia Z3 Compact Main Flex Replacement: step 4, image 2 of 3 Sony Xperia Z3 Compact Main Flex Replacement: step 4, image 3 of 3
    • Release connectors and screw.
  5. Sony Xperia Z3 Compact Main Flex Replacement: step 5, image 1 of 3 Sony Xperia Z3 Compact Main Flex Replacement: step 5, image 2 of 3 Sony Xperia Z3 Compact Main Flex Replacement: step 5, image 3 of 3
    • Remove motherboard.
  6. Sony Xperia Z3 Compact Main Flex Replacement: step 6, image 1 of 3 Sony Xperia Z3 Compact Main Flex Replacement: step 6, image 2 of 3 Sony Xperia Z3 Compact Main Flex Replacement: step 6, image 3 of 3
    • Remove main flex.
Sophia
43,810 Reputation
62 Guides authored
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 22
All Time: 17,130
