Introduction
Remove the main flex cable from the Sony Xperia Z3 Compact motherboard. This includes the button cable.
First, heat up.
And then place the suction cup and pull to open a gap. Insert into the guitar pick to cut the adhesive sticker under the back cover.
Finally, remove the back cover.
Disconnect the NFC antenna.
Unscrew the screws holding the black midframe in place.
Remove back frame.
Remove rear camera bracket.
Release connector, but take care not to damage the electronic components next to the connector. It is best to access the connector from the bottom (battery side), and not from the side as the picture shows.
Remove rear camera.
