Sol Republic Deck Play/Pause Button Replacement
  1. Sol Republic Deck Play/Pause Button Replacement, Play/Pause Button: step 1, image 1 of 3 Sol Republic Deck Play/Pause Button Replacement, Play/Pause Button: step 1, image 2 of 3 Sol Republic Deck Play/Pause Button Replacement, Play/Pause Button: step 1, image 3 of 3
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Pry the front face plate from the bottom half of the speaker by inserting the spudger edge into the the middle groove.
    • Insert another spudger into the middle groove to hold the front plate up as you separate both plates on all sides. Use multiple opening tools to keep plates separated if necessary.
  2. Sol Republic Deck Play/Pause Button Replacement: step 2, image 1 of 1
    • On the front face of the device, locate the green plastic Motorola (M) button that controls the playing and pausing of music.
  3. Sol Republic Deck Play/Pause Button Replacement: step 3, image 1 of 1
    • Using your finger, push the M button towards the inside of the device.
  4. Sol Republic Deck Play/Pause Button Replacement: step 4, image 1 of 1
    • Using the tweezers, grab the button as it comes through and pull it carefully off of the pegs.
Mary Place
170 Reputation
1 Guide authored
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 11
All Time: 887
