Introduction
There is a play/pause button with an "M" on it located on the front cover of the speaker beneath the letters SOL. This button controls the starting and stopping of the music.
Using a metal spudger, pry the front face plate from the bottom half of the speaker by inserting the metal spudger edge into the the middle groove and applying pressure until entry.
Insert one other metal spudger into the middle groove to hold the front plate up as you separate both plates on all sides. Use multiple metal spudgers to keep plates separated if necessary.
On the front face of the device, locate the green plastic Motorola (M) button that controls the playing and pausing of music.
Using the tweezers, grab the button as it comes through and pull it carefully off of the pegs.
