Huawei P20 Pro Interconnect Cable with Charging Port Replacement
  1. Huawei P20 Pro Interconnect Cable with Charging Port Replacement, Rear Glass Replacement: step 1, image 1 of 1
    • Switch off your phone.
    • Use an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
    • The adhesive of the Huawei P20 Pro is of moderate strength, however a hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  2. Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 2, image 1 of 3 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 2, image 2 of 3 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 2, image 3 of 3
    • If the phone's rear glass is cracked, a suction cup may not stick very well. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the rear glass close to the bottom edge of the phone.
    • Lift the bottom edge with the suction cup, opening a slight gap between the rear glass and the frame.
    • Insert an opening pick in the gap and slide it to the bottom right corner. Leave it there to prevent the adhesive from resealing.
  3. Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 3, image 1 of 2 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 3, image 2 of 2
    • Insert a second opening pick and slide it to the bottom left corner. Leave it there to prevent the adhesive from resealing.
  4. Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 4, image 1 of 3 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 4, image 2 of 3 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 4, image 3 of 3
    • Insert a third opening pick at the bottom left corner.
    • Slide the tip of the opening pick along the left edge of the phone to cut the adhesive.
    • Leave the opening pick in the top left corner of the phone to prevent the adhesive from resealing.
  5. Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 5, image 1 of 2 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 5, image 2 of 2
    • In case you're having trouble to cut the adhesive, reapply the iOpener for another minute to loosen it.
    • Insert a fourth opening pick at the top left corner of the phone.
    • Slide the opening pick along the upper edge of the phone to cut the adhesive beneath the rear glass and leave it in the top right corner.
  6. Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 6, image 1 of 3 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 6, image 2 of 3 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 6, image 3 of 3
    • Insert a fifth opening pick at the top right corner of the rear glass.
    • Slide the opening pick along the right edge of the phone to cut the remaining adhesive.
    • Don't open the phone all the way yet. The proximity sensor flex cable is still connected to the motherboard.
  7. Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 7, image 1 of 3 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 7, image 2 of 3 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 7, image 3 of 3
    • Carefully lift the rear glass until you can reach the connector of the proximity sensor flex cable next to the rear camera assembly.
  8. Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 8, image 1 of 2 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 8, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the proximity sensor flex cable.
  9. Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 9, image 1 of 2 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 9, image 2 of 2
    • Remove the rear glass.
    • Before installing fresh adhesive and reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
  10. Huawei P20 Pro Interconnect Cable with Charging Port Replacement, Motherboard Cover and NFC: step 10, image 1 of 1
    • Remove the nine Phillips #00 screws (3.4 mm length).
  11. Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 11, image 1 of 3 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 11, image 2 of 3 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 11, image 3 of 3
    • Insert an opening pick under the left side of the motherboard cover that includes the NFC.
    • Slide the opening pick towards the top left corner of the phone and twist it to pry the cover out of its plastic clamps.
  12. Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 12, image 1 of 2 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 12, image 2 of 2
    • Repeat the previous process on the right side and twist the opening pick to pry up the motherboard cover.
  13. Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 13, image 1 of 1
    • Remove the motherboard cover.
  14. Huawei P20 Pro Interconnect Cable with Charging Port Replacement, Battery Disconnect: step 14, image 1 of 2 Huawei P20 Pro Interconnect Cable with Charging Port Replacement, Battery Disconnect: step 14, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the battery flex cable.
  15. Huawei P20 Pro Interconnect Cable with Charging Port Replacement, Interconnect Cable with Charging Port: step 15, image 1 of 1
    • Remove the five Phillips #00 screws (3.4 mm length).
  16. Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 16, image 1 of 3 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 16, image 2 of 3 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 16, image 3 of 3
    Tool used on this step:
    Buy
    • Use a pair of tweezers to disconnect the antenna cable.
    • Use a pair of tweezers to pull the antenna cable out of its routing.
  17. Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 17, image 1 of 3 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 17, image 2 of 3 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 17, image 3 of 3
    • Slide an opening pick under the left side of the daughterboard cover and start to pry it up until you can get a good grip.
    • Remove the daughterboard cover.
  18. Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 18, image 1 of 1
    • Remove the two Phillips #00 screws (3.4 mm length) on both sides of the USB C port.
  19. Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 19, image 1 of 2 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 19, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the upper end of the interconnect and charging port flex cable from the motherboard.
  20. Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 20, image 1 of 3 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 20, image 2 of 3 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 20, image 3 of 3
    • Use the flat end of a spudger to pry up and disconnect the bottom end of the interconnect and charging port flex cable from the daughterboard.
    • Use a pair of tweezers to move the antenna cable out of the way.
  21. Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 21, image 1 of 3 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 21, image 2 of 3 Huawei P20 Pro Interconnect Cable with Charging Port Replacement: step 21, image 3 of 3
    • Use a pair of tweezers to pull the charging port out of its recess.
    • Remove the interconnect cable including the charging port.
15 other people completed this guide.
Dominik Schnabelrauch
256,026 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
124 Members
25,230 Guides authored
4 Guide Comments
Hallo ich habe alles nach der Anleitung gemacht. Nun geht der Connector wieder, aber ich habe das Problem, das ich innerhalb von Gebäuden kein Netz mehr habe. Außerhalb von Gebäuden kein Problem. Was kann ich tun? Das Antennenkabel weißt auf den ersten Blick keine Beschädigungen auf…
Julian Kern - Reply Share
hola, y.. ¿cuales tipos de pegamentos recomiendan para volver a pegar la tapa trasera? Use Poxiran( cemento de contacto) pero no se adhiere bien al plastico
mar mar mar - Reply Share
Hi, you can use double sided adhesive tape like this one or even pre-cut adhesive for the rear case if you get one for your device on the internet. Poxi-ran could work too after removing old adhesive and if applied carefully only on those areas where there was adhesive.
Tobias Isakeit - Share
dear friend hi. thanks for your perfect explanation but in my case, i wasn’t so able to fix my Huawei P20 charging socket and battery replacement that i had to do. The problem that i have is that the phone now is not charging. when i connect the cable to charge the phone the first 2 sec looks like is charging but after that is stopped. One more problem that i have is when the phone is into the charger and you turn it of is doing a restart by itself. The speaker is working and also the data transfer. Have you ever seen this kind o issue before?
Αντώνης Βλάχος - Reply Share
Past 24 Hours: 10
Past 7 Days: 100
Past 30 Days: 1,062
All Time: 39,860
