Siemes Surpresso Compact coffee outlet Replacement
  1. Siemes Surpresso Compact coffee outlet Replacement, Coffee outlet: step 1, image 1 of 3 Siemes Surpresso Compact coffee outlet Replacement, Coffee outlet: step 1, image 2 of 3 Siemes Surpresso Compact coffee outlet Replacement, Coffee outlet: step 1, image 3 of 3
    • To the left and right of the coffee outlet you will find two slots on the underside of the front cover.
    • Insert a spudger in the front edge of this slot and loosen the clips that fasten the front cover.
    • Pull the front cover forwards and off.
  2. Siemes Surpresso Compact coffee outlet Replacement: step 2, image 1 of 3 Siemes Surpresso Compact coffee outlet Replacement: step 2, image 2 of 3 Siemes Surpresso Compact coffee outlet Replacement: step 2, image 3 of 3
    • The image shows the machine after the front cover has been taken off. The four slots where the clips were are easily recognizable.
    • The movable coffee outlet is surrounded by a casing. Place an opening tool in the gap that separates the two halves of the casing.
    • Slide the tool along the gap, until the front casing becomes loose.
    • Remove the front casing.
  3. Siemes Surpresso Compact coffee outlet Replacement: step 3, image 1 of 2 Siemes Surpresso Compact coffee outlet Replacement: step 3, image 2 of 2
    • Remove the supply tube with a spudger from the connection. Pay attention to the outer wire spiral.
    • Remove the two Torx T15 screws.
    • Remove the black coffee spout.
4 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
202,633 Reputation
246 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,107 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 47
All Time: 4,572
