Siemens Surpresso - Open Bosch Benvenuto
  1. Siemens Surpresso - Open Bosch Benvenuto, Siemens Surpresso - Bosch Benvenuto Brew Group Removal: step 1, image 1 of 3 Siemens Surpresso - Open Bosch Benvenuto, Siemens Surpresso - Bosch Benvenuto Brew Group Removal: step 1, image 2 of 3 Siemens Surpresso - Open Bosch Benvenuto, Siemens Surpresso - Bosch Benvenuto Brew Group Removal: step 1, image 3 of 3
    • Never forget: Pull the power plug!
    • Remove all attachments such as water reservoir, coffee compartment lid, trester drawer.
    • Remove all coffee beans from the bean hopper.
    • Open the side flap.
  2. Siemens Surpresso - Open Bosch Benvenuto: step 2, image 1 of 3 Siemens Surpresso - Open Bosch Benvenuto: step 2, image 2 of 3 Siemens Surpresso - Open Bosch Benvenuto: step 2, image 3 of 3
    • Loosen the three rubber caps on the brew group.
    • Using a strong flat-blade screwdriver, adjust the three plastic slots underneath so that the "unlocked" position is indicated.
    • Note: with the newer version of the brew group, only one lever needs to be flipped.
    • Pull out the brew group. If it is stuck, pull firmly and evenly, but with feeling, preferably at the bottom right.
  3. Siemens Surpresso - Open Bosch Benvenuto, Siemens Surpresso - Bosch Benvenuto back panel removal: step 3, image 1 of 2 Siemens Surpresso - Open Bosch Benvenuto, Siemens Surpresso - Bosch Benvenuto back panel removal: step 3, image 2 of 2
    • Remove the seven Torx T10 screws on the rear panel.
    • Do not remove the back panel completely yet, the power switch is still connected.
    • Lift the back panel away.
    • Remove the two flat plugs from the inside of the power switch.
  4. Siemens Surpresso - Open Bosch Benvenuto, Siemens Surpresso - Bosch Benvenuto top cover removal: step 4, image 1 of 3 Siemens Surpresso - Open Bosch Benvenuto, Siemens Surpresso - Bosch Benvenuto top cover removal: step 4, image 2 of 3 Siemens Surpresso - Open Bosch Benvenuto, Siemens Surpresso - Bosch Benvenuto top cover removal: step 4, image 3 of 3
    • The top cover is engaged with bayonets in several places. It must first be pushed back about 1 cm and then lifted away upwards.
    • Grasp the powder compartment cover firmly and pull it upwards out of its hinges. Otherwise it will be in the way of the top cover.
    • Pull the top cover back about 1 cm. If it sticks in front, you can help a little with plastic levers.
    • Lift the top cover away from the top.
  5. Siemens Surpresso - Open Bosch Benvenuto, Siemens Surpresso - Bosch Benvenuto remove left side panel: step 5, image 1 of 2 Siemens Surpresso - Open Bosch Benvenuto, Siemens Surpresso - Bosch Benvenuto remove left side panel: step 5, image 2 of 2
    • The side panel is attached to the front edge with three bayonets. It must therefore be lifted out upward.
    • Grasp the side panel firmly at the rear edge and pull it backward and upward at the same time. It should come off quite easily.
    • When reassembling, make sure that the bayonets on the front edge engage properly.
  6. Siemens Surpresso - Open Bosch Benvenuto, Siemens Surpresso - Bosch Benvenuto remove right side panel: step 6, image 1 of 1
Follow the steps in reverse order to reassemble your device
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
203,382 Reputation
246 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,121 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 231
