Siemens EQ6 Service Menu
    1. Siemens EQ6 Service Menu, Siemens EQ6 Service Menu: step 1, image 1 of 3 Siemens EQ6 Service Menu, Siemens EQ6 Service Menu: step 1, image 2 of 3 Siemens EQ6 Service Menu, Siemens EQ6 Service Menu: step 1, image 3 of 3
      • Turn the machine on normally.
      • Touch the "Menu" field, it is slightly darker. The settings menu for language, water hardness, etc. appears. But that's not the service menu yet.
      • Touch the first (espresso) and last (hot water) fields in the selection at the same time. The fields are dark.
      • Wait until the selection fields are brightly lit. The service menu appears.
      Ask FixBot
    2. Siemens EQ6 Service Menu: step 2, image 1 of 2 Siemens EQ6 Service Menu: step 2, image 2 of 2
      • You can take the selection one step further by touching the V-shaped area.
      • Start the respective menu item by touching the start/stop area
      • Plenty of items to select from and those are largely self-explanatory (in English).
      • The component test and the sensor test are of particular importance,
      • Other useful items are the error memory and the log files.
      • Press the power button to exit the service menu.
      Ask FixBot
Reverse the steps to reassemble your device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
343,067 Reputation
315 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
41 Members
7,012 Guides authored
23 Guide Comments
Ask for service manual did not get an answer to a simple question
Frank - Reply Share
@frank54967 Try this link for the service manual.
VauWeh - Reply Share
Hallo in die Runde, bei meiner Maschine kann ich das Menue nicht öffnen. Die Tasten sind komplett gesperrt, die Anzeige schreibt zwar 3 sek Menuetaste drücken,aber es passiert nichts. Auch das Drücken der beiden Kaffeetassen Symbole bringt keinen Erfolg. Gibt es einen Trick die Maschine komplett zu redeten?
Tom - Reply Share
Maschine einschalten....Taste "Menü" drücken...dann werden die Felder oben dunkel. Dann die Tasse rechts mit dem +Zeichen drauf gleichzeitig die 1. Tasse links "Espresso" zusammen drücken bis sich das Servicemenue öffnet. Vorsicht beim Setzen auf "Werkseinstellungen" der Bezügezähler geht auf "00000"
Maschine ist EQ6 s300
Helga - Reply Share
Hallo ich habe dieses Komponentenmenü durchgeschaut und bei dem Temperaturtest 78 Grad angezeigt. Ist das normal oder sollte die höher sein?
Carmen Buchholz-Hammer - Reply Share
Past 24 Hours: 16
Past 7 Days: 160
Past 30 Days: 864
All Time: 29,758
