Introduction
The brew group of these appliances can be easily removed for cleaning. The most important seals need to be replaced from time to time. This is shown here.
Note: The brew group of the EQ9 is completely different, the instructions do not apply to it.
''These instructions can also be used with other Siemens/Bosch models - the models have a similar structure.
Picture of the brewing unit. The first gasket to be replaced is on the blue water inlet.
Lift out the cylinder with the lower piston.
Now the brewing unit is largely disassembled. The lower piston can also be removed, but it is usually sufficient to thoroughly clean the parts that have now been removed. Replace the O-ring on the upper piston and on the water inlet (possibly on both ends), grease them and the cylinder thinly with food-grade silicone grease.
Reassemble everything.
To reassemble your device.Work through the steps in reverse order
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
