Xiaomi Mi 11 Lite Rear Glass Panel Replacement
Views: 7.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
31
Past 30 Days:
131
All Time:
7,774
Comments: 1
1 comment on steps.
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace a broken rear glass panel on your Xiaomi Mi 11 Lite.
If you do not replace the adhesive seals when reassembling, your device will function normally, but will most likely lose its water protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
Parts
Tools
    1. Xiaomi Mi 11 Lite Rear Glass Panel Replacement, Heat the rear glass: step 1, image 1 of 1
      • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Xiaomi Mi 11 Lite Rear Glass Panel Replacement, Create a gap: step 2, image 1 of 3 Xiaomi Mi 11 Lite Rear Glass Panel Replacement, Create a gap: step 2, image 2 of 3 Xiaomi Mi 11 Lite Rear Glass Panel Replacement, Create a gap: step 2, image 3 of 3
      • Secure a suction handle to the right edge of the rear glass, as close to the edge as possible.
      • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the rear glass with the suction handle to create a small gap between the rear glass and the frame.
      • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap you created.
      • Slide the opening pick to the top right corner to slice the adhesive.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Ask FixBot
    3. Xiaomi Mi 11 Lite Rear Glass Panel Replacement, Slice the adhesive: step 3, image 1 of 3 Xiaomi Mi 11 Lite Rear Glass Panel Replacement, Slice the adhesive: step 3, image 2 of 3 Xiaomi Mi 11 Lite Rear Glass Panel Replacement, Slice the adhesive: step 3, image 3 of 3
      • Insert a second opening pick underneath the top right corner of your phone.
      • Slide the opening pick along the right edge to slice the adhesive.
      • Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
      Ask FixBot
    4. Xiaomi Mi 11 Lite Rear Glass Panel Replacement: step 4, image 1 of 3 Xiaomi Mi 11 Lite Rear Glass Panel Replacement: step 4, image 2 of 3 Xiaomi Mi 11 Lite Rear Glass Panel Replacement: step 4, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
      • Insert a third opening pick at the bottom right corner of your phone.
      • Slide the opening pick along the bottom edge to slice the adhesive.
      • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Xiaomi Mi 11 Lite Rear Glass Panel Replacement: step 5, image 1 of 3 Xiaomi Mi 11 Lite Rear Glass Panel Replacement: step 5, image 2 of 3 Xiaomi Mi 11 Lite Rear Glass Panel Replacement: step 5, image 3 of 3
      • Insert a fourth opening pick underneath the bottom left corner of your phone.
      • Slide the opening pick along the left edge to slice the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Xiaomi Mi 11 Lite Rear Glass Panel Replacement: step 6, image 1 of 3 Xiaomi Mi 11 Lite Rear Glass Panel Replacement: step 6, image 2 of 3 Xiaomi Mi 11 Lite Rear Glass Panel Replacement: step 6, image 3 of 3
      • Insert a fifth opening pick underneath the top left corner.
      • Slide the opening pick along the top edge of the rear glass to slice the remaining adhesive.
      Ask FixBot
    7. Xiaomi Mi 11 Lite Rear Glass Panel Replacement, Remove the rear glass: step 7, image 1 of 1
      • Remove the rear glass.
      • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      Ask FixBot
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
10 other people completed this guide.
Adriana Zwink
69,355 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,931 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 131
All Time: 7,774
