Shop the Holiday Gift Guide
Screen Removal
View statistics:
Past 24 Hours:
0
Past 7 Days:
4
Past 30 Days:
31
All Time:
412
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Screen Removal
Introduction
Go to step 1 ↓
This is a prerequisite-only guide! This guide is part of another procedure and isn't meant to be used alone.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
  • iPhone 13 Screen
    4.8
Parts
Tools
    1. Screen Removal, Disconnect the display cable: step 1, image 1 of 2 Screen Removal, Disconnect the display cable: step 1, image 2 of 2
      • Use a spudger or a fingernail to disconnect the display cable connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    2. Screen Removal, Unscrew the front sensor connector cover: step 2, image 1 of 1
      • Remove three screws securing the front sensor connector cover:
      • One 1.7 mm Phillips screw
      • One 1.3 mm Phillips screw
      • One 1.8 mm Y000 screw
      Ask FixBot
    3. Screen Removal, Remove the front sensor connector cover: step 3, image 1 of 2 Screen Removal, Remove the front sensor connector cover: step 3, image 2 of 2
      • Swing the cover up from the center of the phone until the small clip by the edge of the phone unhooks.
      Ask FixBot
    4. Screen Removal: step 4, image 1 of 2 Screen Removal: step 4, image 2 of 2
      • Remove the cover.
      • During reassembly, insert the clip on the left edge into its slot first, then hinge the rest of the cover into place.
      Ask FixBot
    5. Screen Removal, Disconnect the front sensors: step 5, image 1 of 2 Screen Removal, Disconnect the front sensors: step 5, image 2 of 2
      • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
      Ask FixBot
    6. Screen Removal, Remove the screen: step 6, image 1 of 2 Screen Removal, Remove the screen: step 6, image 2 of 2
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 13 Answers community for help.
Kyle Smith
53,754 Reputation
124 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 412
