Shop the Holiday Gift Guide
Screen Removal
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
13
All Time:
214
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Screen Removal
Introduction
Go to step 1 ↓
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Follow this guide to replace the screen, without the additional steps to remove the fingerprint scanner cable, in your Samsung Galaxy Tab S7+.
There is a significant chance that you may break the unreinforced and fragile display panel during this procedure. Be sure to apply plenty of heat and be extremely careful during the prying stage.
Parts
Tools
    1. Screen Removal, Heat the bottom edge: step 1, image 1 of 1
      • Completely power off your device before you begin.
      • Apply a heated iOpener to the bottom edge of the device for three minutes to loosen the adhesive underneath.
      • The display adhesive of the Galaxy Tab S7+ is extremely strong, and it's likely you need to reheat and reapply the iOpener several times before starting the display removal and during the removal procedure.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
      Ask FixBot
    2. Screen Removal, Screen removal information: step 2, image 1 of 3 Screen Removal, Screen removal information: step 2, image 2 of 3 Screen Removal, Screen removal information: step 2, image 3 of 3
      • While you're waiting for the adhesive to loosen, note the following:
      • There's a long circuit board attached to the screen that sits parallel to the bottom edge.
      • Don't insert the pick more than 2 mm to avoid damaging the circuit board.
      • This image shows an example of a damaged display separating from the glass panel.
      • Don't insert the pick more than 3 mm to avoid damaging the display.
      Ask FixBot
    3. Screen Removal, Insert an opening pick: step 3, image 1 of 3 Screen Removal, Insert an opening pick: step 3, image 2 of 3 Screen Removal, Insert an opening pick: step 3, image 3 of 3
      • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
      • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction cup to the screen.
      • Lift the screen with the suction handle to create a small gap between the screen and the frame.
      • Insert an opening pick into the gap between the frame and the screen.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Ask FixBot
    4. Screen Removal, Separate the bottom adhesive: step 4, image 1 of 3 Screen Removal, Separate the bottom adhesive: step 4, image 2 of 3 Screen Removal, Separate the bottom adhesive: step 4, image 3 of 3
      • Insert a new opening pick into the gap you created.
      • Slide the new pick along the bottom edge of the device towards the bottom-right corner.
      Ask FixBot
    5. Screen Removal, Heat the right edge: step 5, image 1 of 1
      • Apply a heated iOpener to the right edge of the device for two minutes to loosen the adhesive underneath.
      Ask FixBot
    6. Screen Removal, Separate the bottom-right corner adhesive: step 6, image 1 of 3 Screen Removal, Separate the bottom-right corner adhesive: step 6, image 2 of 3 Screen Removal, Separate the bottom-right corner adhesive: step 6, image 3 of 3
      • Rotate the opening pick around the bottom-right corner of the device.
      Ask FixBot
    7. Screen Removal, Separate the right edge: step 7, image 1 of 3 Screen Removal, Separate the right edge: step 7, image 2 of 3 Screen Removal, Separate the right edge: step 7, image 3 of 3
      • Insert a new opening pick into the gap you created at the bottom right corner.
      • Don't insert the pick more than 3 mm to avoid damaging the components along the right edge.
      • Slide the new pick along the right edge of the device towards the top-right corner.
      Ask FixBot
    8. Screen Removal, Heat the top edge: step 8, image 1 of 1
      • Apply a heated iOpener to the top edge of the device for two minutes to loosen the adhesive underneath.
      Ask FixBot
    9. Screen Removal, Separate the top-right corner adhesive: step 9, image 1 of 3 Screen Removal, Separate the top-right corner adhesive: step 9, image 2 of 3 Screen Removal, Separate the top-right corner adhesive: step 9, image 3 of 3
      • Rotate the opening pick around the top-right corner of the device.
      Ask FixBot
    10. Screen Removal, Separate the top adhesive: step 10, image 1 of 3 Screen Removal, Separate the top adhesive: step 10, image 2 of 3 Screen Removal, Separate the top adhesive: step 10, image 3 of 3
      • Slide the new pick along the top edge of the device towards the top-left corner.
      Ask FixBot
    11. Screen Removal, Heat the left edge: step 11, image 1 of 1
      • Apply a heated iOpener to the left edge of the device to loosen the adhesive underneath.
      Ask FixBot
    12. Screen Removal, Separate the top-left corner adhesive: step 12, image 1 of 3 Screen Removal, Separate the top-left corner adhesive: step 12, image 2 of 3 Screen Removal, Separate the top-left corner adhesive: step 12, image 3 of 3
      • Rotate the opening pick around the top-left corner of the device.
      Ask FixBot
    13. Screen Removal, Separate the left adhesive: step 13, image 1 of 3 Screen Removal, Separate the left adhesive: step 13, image 2 of 3 Screen Removal, Separate the left adhesive: step 13, image 3 of 3
      • Slide the new pick along the left edge of the device towards the bottom-left corner.
      Ask FixBot
    14. Screen Removal, Separate the bottom-left corner adhesive: step 14, image 1 of 3 Screen Removal, Separate the bottom-left corner adhesive: step 14, image 2 of 3 Screen Removal, Separate the bottom-left corner adhesive: step 14, image 3 of 3
      • Rotate the opening pick around the bottom-left corner of the device.
      • At this point, the perimeter of the screen should be separated from the frame. If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
      Ask FixBot
    15. Screen Removal, Remove the screen: step 15, image 1 of 3 Screen Removal, Remove the screen: step 15, image 2 of 3 Screen Removal, Remove the screen: step 15, image 3 of 3
      Tool used on this step:
      Buy
      • Don't try to remove the screen all the way yet; it's still connected by a flex cable.
      • With the top of the device facing you, lift the bottom edge of the screen up and away from you like you're opening a book.
      • Rest the screen upside down before continuing.
      • Be careful not to strain the flex cable.
      • During reassembly:
      • This is a good point to power on your tablet and test all functions before sealing it up. Be sure to power your tablet back down completely before you continue working.
      • Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
      • If you're using custom-cut adhesives, follow this guide. If you're using double-sided tape, follow this guide.
      Ask FixBot
    16. Screen Removal, Disconnect the display cable: step 16, image 1 of 2 Screen Removal, Disconnect the display cable: step 16, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the display cable's press connector from the back of the screen.
      • Be careful not to damage the wide display flex ribbons on the bottom edge of the screen.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    17. Screen Removal: step 17, image 1 of 2 Screen Removal: step 17, image 2 of 2
      • Use tweezers, or your fingers, to hold the display cable in place.
      • Use the flat end of a spudger to pry up and disconnect the fingerprint sensor's press connector attached to the display cable.
      • Take note of the display cable's position—you'll need to bend it in the same way when connecting a new screen.
      Ask FixBot
    18. Screen Removal, Remove the screen: step 18, image 1 of 2 Screen Removal, Remove the screen: step 18, image 2 of 2
      • Remove the screen from the frame.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Tab S7+ Answers community for help.
Author
with
Alex Diaz-Kokaisl
252,776 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,189 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 13
All Time: 214
