Samsung HMX-F90 LCD Screen Replacement
  1. Samsung HMX-F90 LCD Screen Replacement, LCD Screen: step 1, image 1 of 2 Samsung HMX-F90 LCD Screen Replacement, LCD Screen: step 1, image 2 of 2
    • Rotate the camcorder so that back is facing you. Then flip open the LCD screen.
    • Locate and remove the 4.5mm Phillips #00 screws in the LCD screen base.
  2. Samsung HMX-F90 LCD Screen Replacement: step 2, image 1 of 2 Samsung HMX-F90 LCD Screen Replacement: step 2, image 2 of 2
    • Close the LCD screen. Then lift the silver base away from the camcorder.
  3. Samsung HMX-F90 LCD Screen Replacement: step 3, image 1 of 2 Samsung HMX-F90 LCD Screen Replacement: step 3, image 2 of 2
    • Rotate the camcorder so that it is facing you.
    • Locate and remove the two 4.5mm Phillips #00 screws.
  4. Samsung HMX-F90 LCD Screen Replacement: step 4, image 1 of 3 Samsung HMX-F90 LCD Screen Replacement: step 4, image 2 of 3 Samsung HMX-F90 LCD Screen Replacement: step 4, image 3 of 3
    • Open the LCD screen and rotate it around 90 degrees.
    • Locate the small prying notch and use a prying tool to slowly remove the LCD cover.
  5. Samsung HMX-F90 LCD Screen Replacement: step 5, image 1 of 3 Samsung HMX-F90 LCD Screen Replacement: step 5, image 2 of 3 Samsung HMX-F90 LCD Screen Replacement: step 5, image 3 of 3
    • Locate and remove the two 3.5mm Phillips #00 screws holding the back cover.
  6. Samsung HMX-F90 LCD Screen Replacement: step 6, image 1 of 3 Samsung HMX-F90 LCD Screen Replacement: step 6, image 2 of 3 Samsung HMX-F90 LCD Screen Replacement: step 6, image 3 of 3
    • With tweezers gently unclip the silver tab holding the ribbon wire.
    • Gradually feed the ribbon wire through the hole to remove the screen.
Amir Harb
705 Reputation
6 Guides authored
USF Tampa, Team S13-G1, Boczar Fall 2017 Member of USF Tampa, Team S13-G1, Boczar Fall 2017
USFT-BOCZAR-F17S13G1
4 Members
12 Guides authored
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 35
All Time: 1,096
