Samsung Galaxy Tab S3 Display Replacement
  1. Samsung Galaxy Tab S3 Display Replacement, Display: step 1, image 1 of 1
    • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device.
    • We used two iOpeners to open up the tablet. The process is doable with a single iOpener, but would take substantially longer. Alternatively, you can use a heat gun to quickly loosen the adhesive.
    • Leave the iOpener on edge for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
  2. Samsung Galaxy Tab S3 Display Replacement: step 2, image 1 of 1
    • Place a suction cup near edge that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
    • Use an opening tool to split apart the glass panel from the midframe.
    • Be careful to not break the glass when prying from the frame.
  3. Samsung Galaxy Tab S3 Display Replacement: step 3, image 1 of 1
    • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
    • You can also use multiple opening picks instead of a plastic card.
  4. Samsung Galaxy Tab S3 Display Replacement: step 4, image 1 of 3 Samsung Galaxy Tab S3 Display Replacement: step 4, image 2 of 3 Samsung Galaxy Tab S3 Display Replacement: step 4, image 3 of 3
    • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
    • Pull off the glass panel using the suction cup.
    • Carefully disconnect the ribbon connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
  5. Samsung Galaxy Tab S3 Display Replacement: step 5, image 1 of 2 Samsung Galaxy Tab S3 Display Replacement: step 5, image 2 of 2
    • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
Jelly Romero
322 Reputation
1 Guide authored
Cal Poly, Team S22-G4, Maness Spring 2018 Member of Cal Poly, Team S22-G4, Maness Spring 2018
CPSU-MANESS-S18S22G4
5 Members
15 Guides authored
Past 24 Hours: 11
Past 7 Days: 33
Past 30 Days: 163
All Time: 26,684
