This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Introduction
使用本指南来更换失效的主板。
本指南需要移除后盖玻璃,你会需要更换胶水来重新安装回后盖到手机上。
在拆卸你的手机之前,将电池放电到电量25%一下。电池被意外刺破可能会起火或爆炸,但是放电后发生这些的几率会小很多
在锅或平底锅里装满足够的水来完全淹没iOpener。
把水加热到沸腾。关火。
将iOpener放入热水中2-3分钟。确保iOpener完全浸入水中。
用钳子从热水中提取加热的iOpener。
用毛巾彻底擦干iOpener。
你的iOpener已准备好使用!如果你需要重新加热iOpener,请将水加热到沸点,关火,并将iOpener放入水中2-3分钟。
重新涂抹粘合剂后,按照指南相反的顺序重新组装设备。
40 other people completed this guide.
Special thanks to these translators:
81%
Patrick Zhang is helping us fix the world! Want to contribute?
Start translating ›
11 Comments
does the size differ between s8 and s8+?
can i use s8+ motherboard for s8?
Hi Ginthozan, unfortunately the S8+ motherboard is not compatible with the S8, and vice versa.
Are all the connections and motherboard layouts the same for Sprint vs AT&T S8?
Hello i can’t charge my phone (both directly and wireless). I still can turn on my phone by charging it directly to the battery. I have replaced my chsrging port flexible but it didn’t works. I think the ic is broken. There’s two PMIC for s8, PM8998 and SM5720, which one that i should change if i can’t charge my phone? Thankyou
After change my LCD and the motherboard the display screen (!)
