Samsung Galaxy Note8 Battery Disconnect
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Samsung Galaxy Note8 Battery Disconnect, Back Cover: step 1, image 1 of 1
    • Switch off your phone.
    • Prepare an iOpener for softening the adhesive on the back of the Note8.
    • Apply the iOpener on the back of the Note8 along the side with the power button.
  2. Samsung Galaxy Note8 Battery Disconnect: step 2, image 1 of 3 Samsung Galaxy Note8 Battery Disconnect: step 2, image 2 of 3 Samsung Galaxy Note8 Battery Disconnect: step 2, image 3 of 3
    • Use a suction handle to lift the back cover and create an opening pick to get in the gap.
    • Since the back cover is also slightly curved at the edges you want to insert the opening pick at a lower angle from underneath.
    • Start at the middle of the side and cut the adhesive while pulling up with the suction handle.
    • Be careful not to lever the opening pick too much to avoid breaking the back cover. Rather pull with the suction handle and use the pick for cutting the adhesive.
    • Move the pick towards the bottom corner and leave it there to keep the adhesive from resealing to the case.
    • Use another pick and move it to the top corner.
    • If it's getting harder to move the pick you might need to reheat the iOpener and apply it to the back cover again.
  3. Samsung Galaxy Note8 Battery Disconnect: step 3, image 1 of 3 Samsung Galaxy Note8 Battery Disconnect: step 3, image 2 of 3 Samsung Galaxy Note8 Battery Disconnect: step 3, image 3 of 3
    • Again take another opening pick and carefully move it around the corner and along the top edge.
    • Reheat with an iOpener if necessary.
    • Leave the pick at the top right corner to keep the adhesive from resealing.
  4. Samsung Galaxy Note8 Battery Disconnect: step 4, image 1 of 3 Samsung Galaxy Note8 Battery Disconnect: step 4, image 2 of 3 Samsung Galaxy Note8 Battery Disconnect: step 4, image 3 of 3
    • Rotate the device and start to separate the adhesive at the bottom with another opening pick.
    • Leave the pick at the bottom right corner to keep the adhesive from resealing.
  5. Samsung Galaxy Note8 Battery Disconnect: step 5, image 1 of 3 Samsung Galaxy Note8 Battery Disconnect: step 5, image 2 of 3 Samsung Galaxy Note8 Battery Disconnect: step 5, image 3 of 3
    • When the adhesive has been separated on all three sides properly you will be able to slowly lift the back cover.
    • Don't force it open. Use an iOpener to again soften the adhesive if the back cover won't come off or starts to bend.
    • Pay attention to the fingerprint sensor connector when flipping the back cover open. You might need to disconnect it as described in the next step.
  6. Samsung Galaxy Note8 Battery Disconnect: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Use a pair of tweezers to disconnect the fingerprint sensor.
    • The connector might already have come off when flipping the back cover open.
  7. Samsung Galaxy Note8 Battery Disconnect: step 7, image 1 of 1
    • Remove the back cover.
    • To prepare for the reassembly remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
  8. Samsung Galaxy Note8 Battery Disconnect, NFC Antenna and Charging Coil Assembly: step 8, image 1 of 1
    • Remove the ten Phillips #00 screws.
  9. Samsung Galaxy Note8 Battery Disconnect: step 9, image 1 of 2 Samsung Galaxy Note8 Battery Disconnect: step 9, image 2 of 2
    • Use an opening pick at the top edge to get between the NFC antenna and charging coil assembly and the case.
    • Lever the top of the assembly out of the case.
  10. Samsung Galaxy Note8 Battery Disconnect: step 10, image 1 of 1
    • Carefully pull up the complete charging coil and NFC antenna assembly.
    • The bottom left part of the assembly is slightly glued down to the frame.
  11. Samsung Galaxy Note8 Battery Disconnect, Battery Disconnect: step 11, image 1 of 1
    • Use the flat end of a spudger to disconnect the battery connector.
Dominik Schnabelrauch
205,598 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,462 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 62
