Samsung Galaxy Note5 Battery Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Video Overview
    1. Samsung Galaxy Note5 Battery Replacement, Battery: step 1, image 1 of 3 Samsung Galaxy Note5 Battery Replacement, Battery: step 1, image 2 of 3 Samsung Galaxy Note5 Battery Replacement, Battery: step 1, image 3 of 3
      • Heat the edges of the phone up so that the back lifts up evenly without cracking. Use many picks to cut the adhesive and take your time and reheat if necessary.
      Ask FixBot
    2. Samsung Galaxy Note5 Battery Replacement: step 2, image 1 of 2 Samsung Galaxy Note5 Battery Replacement: step 2, image 2 of 2
      • Remove screws.
      Ask FixBot
    3. Samsung Galaxy Note5 Battery Replacement: step 3, image 1 of 3 Samsung Galaxy Note5 Battery Replacement: step 3, image 2 of 3 Samsung Galaxy Note5 Battery Replacement: step 3, image 3 of 3
      • Remove middle housing.
      Ask FixBot
    4. Samsung Galaxy Note5 Battery Replacement: step 4, image 1 of 3 Samsung Galaxy Note5 Battery Replacement: step 4, image 2 of 3 Samsung Galaxy Note5 Battery Replacement: step 4, image 3 of 3
      • Carefully slip a spudger or something thin and sturdy underneath battery. There is adhesive holding it down on the left and right side. DO NOT try to force it as the screen could be damaged.
      • Slowly cutaway at the adhesive on both sides. When that is done the battery should come out with ease.
      • When the adhesive is cut, the battery should come out and you can put your new battery in.
      Ask FixBot
Sophia
43,911 Reputation
62 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 8
All Time: 263
