Samsung Galaxy Note20 Rear Cover Replacement
  1. Samsung Galaxy Note20 Rear Cover Replacement, Heat the rear cover: step 1, image 1 of 1
    • Completely power off your phone before you begin disassembly.
    • Heat an iOpener and apply it to the left side of the rear cover for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the screen, internal battery, and the plastic rear cover are susceptible to heat damage.
  2. Samsung Galaxy Note20 Rear Cover Replacement, Insert an opening pick: step 2, image 1 of 3 Samsung Galaxy Note20 Rear Cover Replacement, Insert an opening pick: step 2, image 2 of 3 Samsung Galaxy Note20 Rear Cover Replacement, Insert an opening pick: step 2, image 3 of 3
    • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
    • Don't insert the opening pick more than five millimeters into the phone or you risk damaging the internal components.
  3. Samsung Galaxy Note20 Rear Cover Replacement, Begin to cut the adhesive: step 3, image 1 of 3 Samsung Galaxy Note20 Rear Cover Replacement, Begin to cut the adhesive: step 3, image 2 of 3 Samsung Galaxy Note20 Rear Cover Replacement, Begin to cut the adhesive: step 3, image 3 of 3
    • Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
  4. Samsung Galaxy Note20 Rear Cover Replacement, Cut along the perimeter of the rear cover: step 4, image 1 of 3 Samsung Galaxy Note20 Rear Cover Replacement, Cut along the perimeter of the rear cover: step 4, image 2 of 3 Samsung Galaxy Note20 Rear Cover Replacement, Cut along the perimeter of the rear cover: step 4, image 3 of 3
    • Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
    • You can insert each new opening pick in the gaps created by the opening picks left in each corner.
    • As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
    • If the rear cover is still attached to the frame after cutting through all four sides, try slicing through the adhesive again with an opening pick.
  5. Samsung Galaxy Note20 Rear Cover Replacement, Remove the rear cover: step 5, image 1 of 2 Samsung Galaxy Note20 Rear Cover Replacement, Remove the rear cover: step 5, image 2 of 2
    • Lift the rear cover straight up to remove it.
Kyle Smith
41,020 Reputation
123 Guides authored
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 52
All Time: 1,360
