Introduction
Use this guide to remove and replace the daughterboard on your Samsung Galaxy Note20.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Heat an iOpener and apply it to the left side of the rear cover for one minute.
Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
Insert an opening pick into the gap.
Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
Tool used on this step:Magnetic Project Mat$19.95
Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
While using a pair of tweezers to hold the motherboard shield out of the way, use the pointed end of a spudger to pry up the battery press connector.
While using a pair of tweezers to hold the motherboard shield out of the way, use the pointed end of a spudger to pry up the wireless charging coil press connector.
Grip the motherboard shield with your fingers.
Peel the wireless charging coil up and away from the device.
Remove the wireless charging coil.
Use a Phillips screwdriver to unscrew the five 4.0 mm screws securing the loudspeaker to the frame.
Insert the pointed end of a spudger underneath the loudspeaker near its top left screw hole.
Use the spudger to pry up and detach the loudspeaker from the frame.
Use a pair of tweezers to lift and remove the loudspeaker.
Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
Use the pointed end of a spudger to disconnect the secondary interconnect cable from the daughterboard.
Use the pointed end of a spudger to disconnect the secondary interconnect cable from the motherboard.
Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
Use a Phillips screwdriver to remove the 2.9 mm screw securing the daughterboard to the frame.
Insert the pointed end of a spudger under the right side of the daughterboard near the screw boss.
Use the spudger to pry up and detach the daughterboard from the frame.
