Samsung Galaxy Note 10.1 2014 Charging Port Replacement
  1. Samsung Galaxy Note 10.1 2014 Charging Port Replacement, Case: step 1, image 1 of 2 Samsung Galaxy Note 10.1 2014 Charging Port Replacement, Case: step 1, image 2 of 2
    Tool used on this step:
    Spudger
    $2.99
    Buy
    • Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
    • If possible, consider using the black nylon spudger for a gentler separation.
  2. Samsung Galaxy Note 10.1 2014 Charging Port Replacement, Battery: step 2, image 1 of 1
    • Place your finger on the thin black bar at the end of the ribbon tape and flip each one up.
    • Gently pull the ribbon tape on the battery away from the bar. Repeat this process for the second ribbon tape.
  3. Samsung Galaxy Note 10.1 2014 Charging Port Replacement: step 3, image 1 of 1
    Phillips #000 Screwdriver
    $5.49
    Buy
  4. Samsung Galaxy Note 10.1 2014 Charging Port Replacement: step 4, image 1 of 2 Samsung Galaxy Note 10.1 2014 Charging Port Replacement: step 4, image 2 of 2
    Spudger
    $2.99
    Buy
    • Lift up the battery from the bottom and situate the black nylon spudger underneath the battery.
    • Use the black nylon spudger to disconnect the multi-colored wires from the rest of the device.
  5. Samsung Galaxy Note 10.1 2014 Charging Port Replacement, Charging Port: step 5, image 1 of 1
    • Using the PH000 screwdriver, remove the two black 3mm screws at the bottom of the device.
  6. Samsung Galaxy Note 10.1 2014 Charging Port Replacement: step 6, image 1 of 2 Samsung Galaxy Note 10.1 2014 Charging Port Replacement: step 6, image 2 of 2
    • After disconnecting the two blue electronic connectors, unhinge the metal part of the charging port with the black nylon spudger.
    • Make sure to also disconnect the other end of the ribbon as well by pushing back the thin black metal bar.
Joseph Rasico
2,173 Reputation
6 Guides authored
USF Tampa, Team S1-G6, Leahy Spring 2017 Member of USF Tampa, Team S1-G6, Leahy Spring 2017
USFT-LEAHY-S17S1G6
3 Members
6 Guides authored
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 51
All Time: 12,810
