Samsung Galaxy Fame S6812i LCD Screen Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the battery cover: step 1, image 1 of 1
    • Make sure that the phone is turned off. Then use your thumb nail or a plastic spudger to pry open the back cover.
  2. Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the battery: step 2, image 1 of 1
    • Use your thumb nail or the plastic opening tool to lift the battery out of the device.
  3. Samsung Galaxy Fame S6812i LCD Screen Replacement, Removing the screws: step 3, image 1 of 2 Samsung Galaxy Fame S6812i LCD Screen Replacement, Removing the screws: step 3, image 2 of 2
    • Remove the five 4 mm screws with a Phillips#00 screwdriver
    • Note: One of the five screws is hidden under a sticker on the bottom left corner of the device.
  4. Samsung Galaxy Fame S6812i LCD Screen Replacement, Removing the mid-frame: step 4, image 1 of 2 Samsung Galaxy Fame S6812i LCD Screen Replacement, Removing the mid-frame: step 4, image 2 of 2
    • Use the plastic opening tool to pry into the bezel to separate the mid-frame from the device
    • Be gentle; the plastic mounting clips are very fragile. Take extra care when working around the volume button.
  5. Samsung Galaxy Fame S6812i LCD Screen Replacement, Removing the internal cover: step 5, image 1 of 3 Samsung Galaxy Fame S6812i LCD Screen Replacement, Removing the internal cover: step 5, image 2 of 3 Samsung Galaxy Fame S6812i LCD Screen Replacement, Removing the internal cover: step 5, image 3 of 3
    • Use the Phillips#00 screwdriver to remove the five black screws.
    • Use the plastic opening tool to lift the two ribbons.
    • Remove the metal internal cover to expose the motherboard.
  6. Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the motherboard: step 6, image 1 of 1
    • Use the plastic opening tool to lift the motherboard out of the device.
  7. Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove and replace the LCD screen: step 7, image 1 of 2 Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove and replace the LCD screen: step 7, image 2 of 2
    • Once you have removed the motherboard you will have access to the LCD screen.
    • Use the plastic opening tool to remove the damaged LCD screen from the display assembly.
    • Put the new LCD screen in place and reassemble the device.
Sarah Brueck
123 Reputation
1 Guide authored
USF Tampa, Team 8-2, Leahy Fall 2014 Member of USF Tampa, Team 8-2, Leahy Fall 2014
USFT-LEAHY-F14S8G2
4 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 956
