Samsung Galaxy Fame S6812i LCD Screen Replacement
  1. Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the battery cover: step 1, image 1 of 1
    • Make sure that the phone is turned off. Then use your thumb nail or a plastic spudger to pry open the back cover.
  2. Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the battery: step 2, image 1 of 1
    • Use your thumb nail or the plastic opening tool to lift the battery out of the device.
  3. Samsung Galaxy Fame S6812i LCD Screen Replacement, Removing the screws: step 3, image 1 of 2 Samsung Galaxy Fame S6812i LCD Screen Replacement, Removing the screws: step 3, image 2 of 2
    • Remove the five 4 mm screws with a Phillips#00 screwdriver
    • Note: One of the five screws is hidden under a sticker on the bottom left corner of the device.
  4. Samsung Galaxy Fame S6812i LCD Screen Replacement, Removing the mid-frame: step 4, image 1 of 2 Samsung Galaxy Fame S6812i LCD Screen Replacement, Removing the mid-frame: step 4, image 2 of 2
    • Use the plastic opening tool to pry into the bezel to separate the mid-frame from the device
    • Be gentle; the plastic mounting clips are very fragile. Take extra care when working around the volume button.
  5. Samsung Galaxy Fame S6812i LCD Screen Replacement, Removing the internal cover: step 5, image 1 of 3 Samsung Galaxy Fame S6812i LCD Screen Replacement, Removing the internal cover: step 5, image 2 of 3 Samsung Galaxy Fame S6812i LCD Screen Replacement, Removing the internal cover: step 5, image 3 of 3
    • Use the Phillips#00 screwdriver to remove the five black screws.
    • Use the plastic opening tool to lift the two ribbons.
    • Remove the metal internal cover to expose the motherboard.
  6. Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the motherboard: step 6, image 1 of 1
    • Use the plastic opening tool to lift the motherboard out of the device.
  7. Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove and replace the LCD screen: step 7, image 1 of 2 Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove and replace the LCD screen: step 7, image 2 of 2
    • Once you have removed the motherboard you will have access to the LCD screen.
    • Use the plastic opening tool to remove the damaged LCD screen from the display assembly.
    • Put the new LCD screen in place and reassemble the device.
Sarah Brueck
123 Reputation
1 Guide authored
USF Tampa, Team 8-2, Leahy Fall 2014 Member of USF Tampa, Team 8-2, Leahy Fall 2014
USFT-LEAHY-F14S8G2
4 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 958
