Introduction
Use this guide to replace the back cover of your Galaxy A5.
Take an iOpener to heat up and soften the glue behind the back cover.
With a suction handle lift lift the back cover to insert an opening pick.
Slide the pick up to the middle to separate the back cover from the frame.
Insert a second opening pick and move around the right corner along the bottom and around the left corner.
Take another opening pick and continue towards the top corner.
Here you want to use one more pick for the last part at the top.
Heat up the back cover once again so you can slide the plastic card towards the top.
Move the plastic card until you reach the camera bump. Now slowly lift up the back cover and finally remove it.
