Samsung Galaxy A5 (2016) Back Cover Replacement
  1. Samsung Galaxy A5 (2016) Back Cover Replacement, Back Cover: step 1, image 1 of 3 Samsung Galaxy A5 (2016) Back Cover Replacement, Back Cover: step 1, image 2 of 3 Samsung Galaxy A5 (2016) Back Cover Replacement, Back Cover: step 1, image 3 of 3
    • Start by switching off your phone.
    • Take an iOpener to heat up and soften the glue behind the back cover.
    • With a suction handle lift lift the back cover to insert an opening pick.
  2. Samsung Galaxy A5 (2016) Back Cover Replacement: step 2, image 1 of 3 Samsung Galaxy A5 (2016) Back Cover Replacement: step 2, image 2 of 3 Samsung Galaxy A5 (2016) Back Cover Replacement: step 2, image 3 of 3
    • Slide the pick up to the middle to separate the back cover from the frame.
    • Insert a second opening pick and move around the right corner along the bottom and around the left corner.
  3. Samsung Galaxy A5 (2016) Back Cover Replacement: step 3, image 1 of 3 Samsung Galaxy A5 (2016) Back Cover Replacement: step 3, image 2 of 3 Samsung Galaxy A5 (2016) Back Cover Replacement: step 3, image 3 of 3
    • Take another opening pick and continue towards the top corner.
    • Here you want to use one more pick for the last part at the top.
  4. Samsung Galaxy A5 (2016) Back Cover Replacement: step 4, image 1 of 3 Samsung Galaxy A5 (2016) Back Cover Replacement: step 4, image 2 of 3 Samsung Galaxy A5 (2016) Back Cover Replacement: step 4, image 3 of 3
    • Insert a plastic card at the bottom and slide it underneath the back cover.
  5. Samsung Galaxy A5 (2016) Back Cover Replacement: step 5, image 1 of 3 Samsung Galaxy A5 (2016) Back Cover Replacement: step 5, image 2 of 3 Samsung Galaxy A5 (2016) Back Cover Replacement: step 5, image 3 of 3
    • Heat up the back cover once again so you can slide the plastic card towards the top.
    • Move the plastic card until you reach the camera bump. Now slowly lift up the back cover and finally remove it.
    • Be sure to remove any residue from the glue and apply new adhesive when reassembling.
Tobias Isakeit
118,058 Reputation
189 Guides authored
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 55
All Time: 48,337
