Samsung BD-H5100 Disk Reader Replacement
  1. Samsung BD-H5100 Disk Reader Replacement, Disk Reader: step 1, image 1 of 1
    • Use the Phillips Head #2 screwdriver to remove the three 10 mm screws on the back panel.
  2. Samsung BD-H5100 Disk Reader Replacement: step 2, image 1 of 3 Samsung BD-H5100 Disk Reader Replacement: step 2, image 2 of 3 Samsung BD-H5100 Disk Reader Replacement: step 2, image 3 of 3
    • Use the plastic spudger to pry open the top panel.
    • Be careful not to break the ribbon connecting the motherboard on the bottom panel to the top panel.
  3. Samsung BD-H5100 Disk Reader Replacement: step 3, image 1 of 2 Samsung BD-H5100 Disk Reader Replacement: step 3, image 2 of 2
    • Pull the ribbons gently from one corner by the blue tabs to remove it.
  4. Samsung BD-H5100 Disk Reader Replacement: step 4, image 1 of 1
    • Remove the two 7.5 mm screws on both sides of the disk tray with Phillips Head #2 screwdriver.
  5. Samsung BD-H5100 Disk Reader Replacement: step 5, image 1 of 2 Samsung BD-H5100 Disk Reader Replacement: step 5, image 2 of 2
    • Push two small prongs on both sides inwards and push forward.
    • Remove the disk tray.
  6. Samsung BD-H5100 Disk Reader Replacement: step 6, image 1 of 1
    • Flip the disk tray upside down.
  7. Samsung BD-H5100 Disk Reader Replacement: step 7, image 1 of 1
    • Use the Phillips Head #00 screwdriver to remove the four 6.2 mm corner screws.
  8. Samsung BD-H5100 Disk Reader Replacement: step 8, image 1 of 1
    • Flip the disk reader up like a flip phone.
    • Be careful not to break the ribbon.
  9. Samsung BD-H5100 Disk Reader Replacement: step 9, image 1 of 2 Samsung BD-H5100 Disk Reader Replacement: step 9, image 2 of 2
    • Pull the ribbon out gently from one corner by the blue tab.
Mira Patel
580 Reputation
5 Guides authored
USF Tampa, Team 1-2, Leahy Fall 2016 Member of USF Tampa, Team 1-2, Leahy Fall 2016
USFT-LEAHY-F16S1G2
3 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 14
All Time: 635
