Saeco Royal Pump Replacement
  1. Saeco Royal Pump Replacement, Preparing: step 1, image 1 of 1
    • Unplug!
    • Remove all attachments like water tank, brewing unit etc.
    • The pictures show a Royal Cappucino One Touch HD8930, but the opening procedure is similar to all models.
  2. Saeco Royal Pump Replacement, Top: step 2, image 1 of 2 Saeco Royal Pump Replacement, Top: step 2, image 2 of 2
    • The coffeebean supply is fixed with two screws. Unscrew them and lift it off.
    • There is a black rubber lid under the bean hopper that you can easily lift off, leaving a large opening.
    • The adjuster of the grinder has to be solved. Mark the position or just take a picture. This type is fixed with a screw, others are only sticked together.
  3. Saeco Royal Pump Replacement, Rear side: step 3, image 1 of 1
    • There are two screws to be turned out.
  4. Saeco Royal Pump Replacement, Front: step 4, image 1 of 3 Saeco Royal Pump Replacement, Front: step 4, image 2 of 3 Saeco Royal Pump Replacement, Front: step 4, image 3 of 3
    • The screws are situated on the underneath of the cover. This type is held by four screws.
  5. Saeco Royal Pump Replacement, Lift cover off: step 5, image 1 of 2 Saeco Royal Pump Replacement, Lift cover off: step 5, image 2 of 2
    • Now the cover can be raised: first grip on left and right rear side and lift about 10 cm (4 in). Sometimes the cover jams a little bit.
    • Solve the hoses which lead to the water tank. Perhaps you have to pull out some contacts, (e.g. the yellow-green protection lead), don´t forget to put them on again later.
    • The cover can be drawn aslant towards the front, sliding it over the hot water pipe.
    • Most repairs can be done with the cover being laid up partially , it must not be completely removed.
  6. Saeco Royal Pump Replacement, Remove thermoblock: step 6, image 1 of 1
    • This is what the removed thermoblock looks like. This one was 14 years old and leaking in various places.
  7. Saeco Royal Pump Replacement: step 7, image 1 of 2 Saeco Royal Pump Replacement: step 7, image 2 of 2
    • A look into the open device. The thermoblock is hidden under a pile of cables and tubes.
  8. Saeco Royal Pump Replacement: step 8, image 1 of 1
    • It's safer to number the cable connectors on the electronics. You probably just need to disconnect the slightly hidden # 14 connector on the two green cables at the very bottom and # 7 on the blue cable on the top.
  9. Saeco Royal Pump Replacement: step 9, image 1 of 1
    • The thermoblock is attached to the wall behind the brew group with only two Phillips screws.
    • Remove the two Phillips screws circled in red.
  10. Saeco Royal Pump Replacement: step 10, image 1 of 1
    • Take out the thermoblock and place it on the machine.
    • Hold on! The thermoblock is still connected to the machine by many cables and hoses. Don't attempt to completely remove it just yet!
  11. Saeco Royal Pump Replacement: step 11, image 1 of 2 Saeco Royal Pump Replacement: step 11, image 2 of 2
    • Pull the clamp on the hose to the steam valve off.
    • Pull the hose circled in orange out.
    • There are two seals at the end of the hose that stick to the hose. Exchange them during re-assembly.
  12. Saeco Royal Pump Replacement: step 12, image 1 of 1
    • Remove the metal holder of the thermal fuse.
    • My thermal fuse holder is heavily rusted, this may or may not be the case for you.
  13. Saeco Royal Pump Replacement: step 13, image 1 of 1
    • Pull first the clamp, and then the second pressure hose out of the thermoblock.
    • There are two seals at the end of the hose. They stay stuck either at the end of the hose or afterwards, so don't try to remove them. Exchange them during re-assembly.
  14. Saeco Royal Pump Replacement: step 14, image 1 of 2 Saeco Royal Pump Replacement: step 14, image 2 of 2
    • Disconnect the connector with the two gray cables from the thermal switch.
  15. Saeco Royal Pump Replacement: step 15, image 1 of 1
    • The blue cable from the thermoblock leads to the connector on the electronics, which is marked with 7 here. This particular plug stuck a lot, so force was required to pull it out.
  16. Saeco Royal Pump Replacement: step 16, image 1 of 3 Saeco Royal Pump Replacement: step 16, image 2 of 3 Saeco Royal Pump Replacement: step 16, image 3 of 3
    • The Allen screw, which holds the holder of the two thermocouples, was not easy to open...
    • This can also be a Phillips screw. It may vary which appears for you.
    • Therefore, the plug on the electronics with the two green cables was pulled out. The plug has the mark 14 and is at the very bottom of the electronics.
    • Disconnect the plug with the yellow-green grounding wire from the support valve.
  17. Saeco Royal Pump Replacement: step 17, image 1 of 1
    • Thread the green and blue cables out.
    • The thermoblock is free. Lift it out of the machine.
    • To replace the thermoblock, the attached components must be removed from the old block and transferred to the new part.
  18. Saeco Royal Pump Replacement, Pump: step 18, image 1 of 2 Saeco Royal Pump Replacement, Pump: step 18, image 2 of 2
    • Here the pump viewed from above, a Ulka EX5 with 230V. The pump is stored in rubber pieces.
    • Pull the silicone hose off the rear elbow.
    • If not already done, remove the clamp on the pressure hose on the pressure relief valve. Then remove the pressure hose.
    • The pressure hose is sealed with two O-rings at the end. These will usually hang at the end. Replace them before re-assembling.
  19. Saeco Royal Pump Replacement: step 19, image 1 of 3 Saeco Royal Pump Replacement: step 19, image 2 of 3 Saeco Royal Pump Replacement: step 19, image 3 of 3
    • In the first picture, the pump has already been removed. The red marking shows the catch that holds the rubber molded part. You can easily pull it out when the catch is pressed down.
    • Pull the angled molded rubber parts out of their spots on the floor.
    • Lift the pump with the rubber moldings out of the machine.
    • When reassembling, make sure that the molded rubber part is correctly attached.
To re-assemble your device, follow the steps in reverse order.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
203,989 Reputation
246 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,129 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 61
All Time: 7,977
