Saeco Odeo brewing unit gasket replacement
  1. Saeco Odeo brewing unit gasket replacement, Brewing unit gasket: step 1, image 1 of 2 Saeco Odeo brewing unit gasket replacement, Brewing unit gasket: step 1, image 2 of 2
    • Open the hatch on the side panel and remove the brewing unit.
  2. Saeco Odeo brewing unit gasket replacement: step 2, image 1 of 1
    • The spout for the hot coffee is located on the top of the brewing unit. It is fastened with two screws. Underneath is the crema valve. It consists of a spring and a little glass ball. Make sure the spring is reinserted with the thin end touching the glass ball when re-assembling.
    • Remove the two Torx T10 screws on the crema valve.
    • Lift off the crema valve minding the spring and the glass ball.
  3. Saeco Odeo brewing unit gasket replacement: step 3, image 1 of 1
    • The upper piston is held in place in the frame with four locking pawls. Push down all four latches with a spudger, then remove the piston by pushing it downward.
    • If you want to replace the gasket, you can do this now and re-assemble the device and stop here. However, a general maintenance of the brewing unit is strongly recommended.
    • Unscrew the Torx T10 screw on the brewing sieve and remove it.
  4. Saeco Odeo brewing unit gasket replacement: step 4, image 1 of 3 Saeco Odeo brewing unit gasket replacement: step 4, image 2 of 3 Saeco Odeo brewing unit gasket replacement: step 4, image 3 of 3
    • There are three Torx T10 screws in deep blind holes that hold together the two parts of the brewing unit. Unscrew them and lift off the upper side panel.
  5. Saeco Odeo brewing unit gasket replacement: step 5, image 1 of 2 Saeco Odeo brewing unit gasket replacement: step 5, image 2 of 2
    • Now you can disassemble the brewing unit into its three main parts: the brewing unit and the two side panels.
  6. Saeco Odeo brewing unit gasket replacement: step 6, image 1 of 2 Saeco Odeo brewing unit gasket replacement: step 6, image 2 of 2
    • You can push out the lower piston from the brewing unit if you snap the deflection lever out of its socket with a screw driver.
    • Clean all parts with very hot water and dishwasher liquid.
    • Grease all moving parts with food grade silicone fat. Dont forget the tracks in the side panels.
Follow the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
VauWeh is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
202,869 Reputation
246 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,110 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 24
All Time: 2,027
