Introduction
Most repairs require the espresso machine to be opened. This is shown here. Please note that there are models with a decorative frame made of metal (shown here) and others made of plastic.
First check which model you have in front of you: Is the decorative frame made of chromed metal (picture 1) or of metallized plastic? (picture 2). In the second case follow this guide, in the first case you are in the right place here.
Remove the 4 Torx T10 screws.
The upper part of the right metal frame is secured by 2 partially hidden Torx T10 screws. You can reach the back one of the two through the opening in the right corner in the back. Loosen the screw in order to slide the metal frame slightly outwards.
Remove the 2 screws holding the closing mechanism for the bean storage container.
The screw at the front of the metal frame should now be within reach and you can remove the metal frame completely. This wasn't done this way here however.
4 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
7 Comments
I got it open, the reason I opened it was because when I turn the power on, nothing happened, any suggestions?
If there is no power, you may have to check if there is any fuse which is gone.
But normally a fuse is not burning without a reason. So there could be some other defect, maybe water is dripping onto some elctronic circuit or also maybe the power supply is dead.
Be careful when working with/near main voltage!
Great instruction! I had to open my Moltio before and it took me some time to figure out how to do without breaking anything.
echt super diese Anleitung! Hoffe auf weitere solche Beiträge. Mit freundlichen Grüßen
There is a tool sign and number 22 on the screen. Can someone help me please
