Removal of the Saeco Exprelia top cover
  1. Removal of the Saeco Exprelia top cover, Open the rear cover of the Saeco Exprelia: step 1, image 1 of 1
    • Remove all accessory parts like the water reservoir, the brewing assembly as well as the drip try.
    • Remove all coffee beans from the bean container
    • Always remove the power cord
    • Remove the two T10 Torx screws from the bottom of the rear cover.
  2. Removal of the Saeco Exprelia top cover: step 2, image 1 of 1
    • Pull the back cover approximately 1 cm (3/8inch) out from the bottom and push it in an upward direction.
  3. Removal of the Saeco Exprelia top cover, Loosening the Saeco Exprelia rear frame: step 3, image 1 of 2 Removal of the Saeco Exprelia top cover, Loosening the Saeco Exprelia rear frame: step 3, image 2 of 2
    • Remove the five T10 Torx screws as marked
    • the back frame consist of 3 pieces. Lift the top part out first, then each one of the side pieces
  4. Removal of the Saeco Exprelia top cover, Removal of the Saeco Exprelia top cover: step 4, image 1 of 3 Removal of the Saeco Exprelia top cover, Removal of the Saeco Exprelia top cover: step 4, image 2 of 3 Removal of the Saeco Exprelia top cover, Removal of the Saeco Exprelia top cover: step 4, image 3 of 3
    • Lift the bean compartment lid and loosen the Torx T10 screw.
    • Open the water compartment lid and loosen the Torx T10 screw.
    • The lid is locked into place several times. Carefully loosen the catches and lift off the lid.
    • Note: If you only want to remove the left cover on the water compartment, all you need to do is loosen the cover a little and lift it up by about 2 cm.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
203,382 Reputation
246 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,121 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 32
All Time: 2,085
