Disassembling the Saeco Exprelia
  1. Disassembling the Saeco Exprelia, Open the rear cover of the Saeco Exprelia: step 1, image 1 of 1
    • Remove all accessory parts like the water reservoir, the brewing assembly as well as the drip try.
    • Remove all coffee beans from the bean container
    • Always remove the power cord
    • Remove the two T10 Torx screws from the bottom of the rear cover.
  2. Disassembling the Saeco Exprelia: step 2, image 1 of 1
    • Pull the back cover approximately 1 cm (3/8inch) out from the bottom and push it in an upward direction.
  3. Disassembling the Saeco Exprelia, Loosening the Saeco Exprelia rear frame: step 3, image 1 of 2 Disassembling the Saeco Exprelia, Loosening the Saeco Exprelia rear frame: step 3, image 2 of 2
    • Remove the five T10 Torx screws as marked
    • the back frame consist of 3 pieces. Lift the top part out first, then each one of the side pieces
  4. Disassembling the Saeco Exprelia, Removal of the Saeco Exprelia top cover: step 4, image 1 of 3 Disassembling the Saeco Exprelia, Removal of the Saeco Exprelia top cover: step 4, image 2 of 3 Disassembling the Saeco Exprelia, Removal of the Saeco Exprelia top cover: step 4, image 3 of 3
    • Lift the bean compartment lid and loosen the Torx T10 screw.
    • Open the water compartment lid and loosen the Torx T10 screw.
    • The lid is locked into place several times. Carefully loosen the catches and lift off the lid.
    • Note: If you only want to remove the left cover on the water compartment, all you need to do is loosen the cover a little and lift it up by about 2 cm.
  5. Disassembling the Saeco Exprelia, Remove the Saeco Exprelia left cover on the water compartment: step 5, image 1 of 1
    • Open the front access door.
    • Lift the top cover by about 2 cm until you can just reach the screw in the top right.
    • Remove the T10 Torx screw
  6. Disassembling the Saeco Exprelia: step 6, image 1 of 1
    • Lift the top cover slightly upwards. It requires a fair amount of force to push the side cover upwards by about 5 mm until the hooks are released and then lift it out.
Work through the steps in reverse order to reassemble your device.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
VauWeh is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
202,795 Reputation
246 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,109 Guides authored
3 Comments
Hallo. Ich habe das Problem das ich die Antriebs Zahnräder der Brühgruppe der Saeco Exprelia HD8855 falsch eingesetzt habe. Kann mor da einer helfen?
Andre - Reply
Zur Orientierung hilft vielleicht das hier: Saeco Royal Cogwheel replacement, Schritt 23: Setze das graue Zahnrad beim Einbau so ein, dass die Nullmarkierung auf die Achse des weißen Zahnrads zeigt.
VauWeh -
Past 24 Hours: 5
Past 7 Days: 52
Past 30 Days: 219
All Time: 7,647
