Saeco brewing unit disassembly
  1. Saeco brewing unit disassembly, Cream valve and spout: step 1, image 1 of 3 Saeco brewing unit disassembly, Cream valve and spout: step 1, image 2 of 3 Saeco brewing unit disassembly, Cream valve and spout: step 1, image 3 of 3
    • These parts differ in details depending on the model
    • Two screws hold the part, loosen. A seal becomes free, pick up well, better still replace later.
    • Inside is a feather and a small glass ball. Store carefully.
  2. Saeco brewing unit disassembly, The brewing sieve: step 2, image 1 of 2 Saeco brewing unit disassembly, The brewing sieve: step 2, image 2 of 2
    • With a 6mm Allen key (or the key that comes with the machine), the brewing sieve can be unscrewed. It strongly determines the aroma, if it is dirty the coffee tastes bad.
  3. Saeco brewing unit disassembly, The upper piston: step 3, image 1 of 3 Saeco brewing unit disassembly, The upper piston: step 3, image 2 of 3 Saeco brewing unit disassembly, The upper piston: step 3, image 3 of 3
    • He is held in place by four latches. These impress, e.g. with a screwdriver, then the piston can be pushed down.
    • The new sealing ring is already waiting, but first it has to be cleaned properly.
  4. Saeco brewing unit disassembly, Intake: step 4, image 1 of 3 Saeco brewing unit disassembly, Intake: step 4, image 2 of 3 Saeco brewing unit disassembly, Intake: step 4, image 3 of 3
    • Through the hole on the opposite side of the fixing screw can be solved. The inlet is plugged in and held by a latch, which you have to push away.
  5. Saeco brewing unit disassembly, dismantle: step 5, image 1 of 3 Saeco brewing unit disassembly, dismantle: step 5, image 2 of 3 Saeco brewing unit disassembly, dismantle: step 5, image 3 of 3
    • Three screws hold the brew groups together, loosen.
    • The whole mechanics can now be broken down into three big parts. The coffee funnel can stay.
  6. Saeco brewing unit disassembly, Umlenkhebel: step 6, image 1 of 2 Saeco brewing unit disassembly, Umlenkhebel: step 6, image 2 of 2
    • That's the trickiest part: you have to lever this lever out of its camp. To do this you drive with a screwdriver between the lever and the carrier and press it really very strong outwards. Now he grabs out - hopefully!
  7. Saeco brewing unit disassembly, Lower piston: step 7, image 1 of 1
    • Since the lever is gone you can easily pull out the piston. It has no seal.
    • The lower piston itself has no gasket. But the shaft of the piston slides in an o-ring. which is situated under the brewing chamber. It can be changed, but it´s not easy to do this.
  8. Saeco brewing unit disassembly, Clean: step 8, image 1 of 1
    • That's why we did it. All parts are thoroughly cleaned. For this purpose, a solution of machine detergent is good. (Use rubber gloves!) Clean all channels with pipe cleaners. The brewing sieve is like new again! Allow to dry well.
    • Then apply new gaskets, in particular to the crema valve and piston and lubricate with food-grade grease.
    • Fat also belongs to the bearings of the rocker arm and into the slides, the piston skirt, as well as into the water inlet
Repeat the steps in order to reassemble your device.
3 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
204,177 Reputation
246 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,132 Guides authored
5 Comments
How does the metal bar you see in figure 7 get put back in place when you reassemble the unit?
milesj - Reply
Not easy to describe. First try to use the brewing unit without the metal, maybe that's already enough. Or try borrowing another unit to compare.
VauWeh - Reply
i dismantled only the square part to clean the metal filter. A 1mm seal fell out of no where and wasnt sure where to put it back. I placed it back into that L shape piece on top of it and now there is some coffe leaking into the square piece. Please help. I have the diagram to show the exact piece i mentioned but how do i show it here?
Jelim - Reply
I suppose it is the seal visible in Saeco brewing unit disassembly, step 1, picture 3. Be sure to put in the little ball, the spring and the seal, before you tighten the screws on the L-shaped hose. There is another gasket on the axis in step 2, picture 1, perhaps you removed it?
VauWeh -
Once I saw someone put the L-shaped hose in the wrong way. The exit must point into the machine.
VauWeh -
Past 24 Hours: 12
Past 7 Days: 70
Past 30 Days: 415
All Time: 21,466
